Replaced a rear caliper on my 2010 Tundra last fall, and it's never been the same since. Low pedal for a while. I recently bled the brake some more (both rears, just cracked the bleeders as my Mityvac refuses to properly pull brake fluid) and that helped. But it feels like the brakes are just not there--really have to push to get decent braking. Almost like a booster issue, or bad bite on the brake pads. And no, pedal is not going to the floor, it just seems harder than it should be--not as hard as having zero power brakes, but nothing like my other two vehicles.
I let it sit for four hours (engine off of course) and it still had vacuum in the booster. So I'm thinking not a booster.
I did have new OEM pads and rotors put on 1.5 years ago. I then drove it very little, like 4,000 miles over the next year, maybe 1,000 miles this winter. It sits--a lot. And outside. Could the pads be wonky? Should I do some high speed braking events and check to make sure all four heat up properly? I'm thinking that is first thing to check, maybe one end or the other isn't doing its job. I did not do the pad install but I'm not entirely sure how they could be screwed up--and I'm not dragging a brake either (no hot rotors when I park). I'm 99% sure I got the better OEM pads, but I'd have to look.
Both rotors appear to be doing something, as they are mostly clear of rust. [Sometimes you can spot a dead caliper as the rotor is crusty as all get out. Not the case here.]
