The Amsoil corporate website indicates the Severe Gear 75w-90 lube oil is compatible with most LSD's. Does anyone know what the percentage of friction modifer is in a quart of the lube? I'm guessing that it would be 4% to 6%.
MolaKule, are you saying that the 4 oz bottle of FM that I buy at the Dodge parts place has very little FM and that it's mostly carrier? It sure looks like FM to me when I pour it.quote:
The actual percentage of LS friction modifier in diffy lubes from the lube manf. is on the order of 0.8% to 1.5%, since it is a specially compounded and concentrated phosphorus-based product (a thick phoshorus ester).
The 4 or 7 oz. stuff you get in a tube from say Autozone or wherever has been diluted so it can be poured easily.
Now the friction modifier to reduce bulk friction and viscous drag is usually provided by one of the base oil components and is generally a POE ester.
BTW, anytime you handle this stuff, please glove since phosphorus esters have a propensity for damaging the liver.
The actual percentage of LS friction modifier in diffy lubes from the lube manf. is on the order of 0.8% to 1.5%, since it is a specially compounded and concentrated phosphorus-based product (a thick phoshorus ester).quote:
