Originally Posted By: davison0976
Amsoil SS MSDS says base oils 30-60% CAS Numbers 64742-54-7, 64742-65-0
And if you look up the CAS numbers then,
64742-54-7 Petroleum distillates, hydrotreated heavy paraffinic
This product may be regulated, have exposure limits or other information identified as the following: Mineral Oil
64742-65-0 Distillates (petroleum), solvent-dewaxed heavy paraffinic
Streams obtained from vacuum distillates, vacuum residues and atmospheric distillation residues by processes such as solvent extraction or hydrogenation, and containing saturated and aromatic hydrocarbons, mainly in the range C10 to C50.
Here are the links:
http://www.amsoil.com/msds/azo.pdf
http://www.amref.com/Media/Files/ind_msds/R11_4315_KENDEX_0150H.pdf
https://s00.static-shell.com/content/dam...n-20.5mm2-s.pdf
I am not totally sure, but that looks like Group III to me, which I personally don't have a problem with, and I do use Amsoil products.
Yep, Amsoil no longer advertises that their signature series oil is 100% PAO because it no longer is. It is clearly a blend at this point, not unlike the M1 EP series oils (that you can get for half the price in multiple locations). SS is fortified with a big additive package for the advertised extended drain intervals. Excellent oil still, but not the Unicorn Blood they advertise it as.
XL and OE are group III oil with the XL having a stouter additive package.
