The car had 14,274 miles on it with this drain. 8 month interval. About a 50/50 mix of driving, and not afraid to see the upper parts of the rpm band. This is the 2nd analysis I have done, mainly because this engine is very noisy on cold starts. Sounds just like a diesel till the temp gauge starts to move. The history on the car is went 3030 on factory fill, 1885 on Pennzoil 5w/20(dealer changed), 2047 on QuakerState 5w/20 and then this change of 7312 on the 0w/20. I went with the 0w/30 SSO for the current fill. First column is the 0w/20 Amsoil, 2nd column is the 5w/20 QuakerState, then the last column is the universal average. This Elantra has had the factory Hyundai filters each time and has been getting Amsoil PI about every 4000 miles.
Alum...3...1...2
Chrom..1...0...1
Iron..13...6...9
Copper.6...5...3
Lead...0...0...1
Tin....2...0...1
Moly...5..41..54
Nickel.0...0...0
Mangan.1...1...0
Silver.0...0...0
Titan..0...0...0
Potass.2...0...1
Boron..15.159.45
Silic.12...5...7
Sodium.6...3...15
Calc.2599.1514.2322
Magnes.10..7...77
Phosp.578.569.706
Zinc.667.677..847
Barium.1...0...1
1st column Ams0w/20, second column 5w/20 QuakerState
SUS Vis 53.3...51.4 should be 46-59
cST visc 8.26..7.70 should be 6.0-10.2
Flashpnt 370...375 should be >385
Fuel% .8 ... Antifreeze 0....0 should be 0
Water% 0...0 should be 0
insolubles% .3...<0.5 should be <0.6
Alum...3...1...2
Chrom..1...0...1
Iron..13...6...9
Copper.6...5...3
Lead...0...0...1
Tin....2...0...1
Moly...5..41..54
Nickel.0...0...0
Mangan.1...1...0
Silver.0...0...0
Titan..0...0...0
Potass.2...0...1
Boron..15.159.45
Silic.12...5...7
Sodium.6...3...15
Calc.2599.1514.2322
Magnes.10..7...77
Phosp.578.569.706
Zinc.667.677..847
Barium.1...0...1
