I'd also check for AC ripple voltage at the battery terminals. That needs to be minimal too. Large variations could indicate failing diode(s), which can simulate an undercharged battery. My car has been doing something similar and I show decent alternator voltages, currents, and resistances. Yet the next day my battery drops to 12.3 volts (will not charge above 12.6v on my battery charger). While there is a draw of some sort, it has eluded me. With the car at idle and all accessories on, my idling battery voltage drops from 14.2 (no accessories) to 13.8v. Which is fine. It's confusing to me since the accessories don't draw all that much. When I put the battery on a charger it starts out at 8 DC amps down to 4 amps over 45 minutes. At that point, the charging current will not drop (suggesting a real 4 amp draw). Logically, a 4-5 amp draw should KILL the battery within 24 hours. And there are no 5 amp running loads in the car. The car runs and starts fine all the time, even after sitting for 2-3 days. The battery is only 1 year old. The alternator is 16 years old.
