There are rebuild kits with nippon denso parts, but I can't seem to find a slip ring for itDo what the cheap volume remanufacturers do. Clean then paint the case/outer housing, slap some brushes in it and SEND it..
Actually, sometimes one can buy a new slip ring setup from an alternator/starter supply house and fix it the right way. If it is the OEM alternator, you might want to keep the stator and rotor and rebuild the unit with slip rings, bearings and brushes.
car has 298k miles on it and I'm pretty sure this is an oem one, it's a denso alternator.I'd run it. How many miles on the alternator?
is there a way to bench test the regulator? the voltage dipped below 12 while the car was running.I would not change the regulator or rectifier. Oem is probably the best quality and has proven itself to work thus far. I would clean everything up and put new bearings, brushes, and slip ring and call it a day.
Im not sure if you can bench test just the voltage regulator. Often if the voltage dips low on an alternator that looks like that with worn brushes and a bad slip ring it could be that the contact between the ring and brush is gone and not charging the battery although i would expect the alternator light to illuminate if that happened. Only way i know to test is to run the vehicle and measure the voltage with a multimeteris there a way to bench test the regulator? the voltage dipped below 12 while the car was running.
Honestly, it's not too much work to pull it out and replace it with a new one, I'll just get the slip ring, bearings, and brush assembly and run it. Going to clean up the whole assembly too since it was covered in oilDepending on the vehicle the voltage regulation might be performed by the ECU. That is why there are so many wires going to that plug. Looks like there are four wires. The regulator in the alternator is a backup and is only used when communication with the ECU is lost. I'm only saying this because replacing the voltage regulator in the alternator could be a waste of time/money. I would look at the wiring diagram for this car.
