I've got a 2001 F150 with a 4.6 and 180k on the clock.
Recently i've noticed an unusual behavior. Under full throttle at higher speeds, the battery light on the dash flickers. If it's dark outside, the dash lights and head lights dim a little. It only does this if I'm running at hwy speeds (60+) and put the pedal to the floor to pass. Also, only when it downshifts twice, to really bring the rpms up into the higher end of the power band. It's easily replicated in this situation. The needle on the battery gauge on the dash does not drop when this occurs. And it will not do this under full throttle accelerating off the line, like 0-60, but i have not tried to take off from a dead stop and hold it on the floor all the way up to 80 or 90 mph.
First thought is alternator can't keep up with the load when the injectors and coils are firing at that high of an RPM, but every time i've seen an alternator fail in the past, they lacked the ability to keep up with demand at the low end of the rpm spectrum and the issues cleared up as RPM's climbed. This one seems to do the opposite.
Thoughts?
Thoughts?
