3.5L SOHC V6 VTEC, 5 sp Auto, FWD/AWD
Oil Use = Nov '03 - Apr 7 '04
OEM air filter
Purolator Plus oil filter
Oil Fill 4.5 qts
Make-up ~.5 qts
Primary use - to/from work - 6miles each and other short trips around town - VTEC do get some excercise once in a while.
[ April 14, 2004, 08:35 AM: Message edited by: pinoy99 ]
OEM air filter
Oil Fill 4.5 qts
Make-up ~.5 qts
Oil was changed and refilled with same. Using Toyo Roki 15400-PCX-004 oil filter this time. Will probably use Mobil1 0w-20 on future fill.code:
factory fill synergyn synergyn voa
total mi 3850 11125 from 2slick
al 12 7
Cr 3 2
Fe 83 25
Cu 164 61
Pb 5 1
Sn 1 0
Mo 332 81 148
Ni 0 0
Mn 4 1
Ag 0 0
Ti 0 0
K 2 0
B 19 65 168
Si 74 6 6
Na 10 3
Ca 1902 2098 3205
Mg 6 5 47
P 756 877 1485
Zn 829 939 1479
Ba 8 0
Sus Vis@210 = 50.7 55.5
Flashpoint = 385 375
Fuel % = < 0.5
Insolubes = 0.6 0.5
TBN 3.7
