[ January 02, 2003, 03:31 PM: Message edited by: Mike ]
02 Z28 here with SLP lid. I bought the Kool Blue for this car and put it in, but took it out fearing that it wouldn't filter as well as the paper ones (thanks for scaring me guys). The filter seems to be good quality and fits very well (KP4020)quote:
Originally posted by Ryan00TJ:
Mike, How does your Accel filter fit in your airbox? I am also looking for a new filter, but an torn between K@N, Holley and the Accel. Also do you have the stock airbox or an aftermarket lid? I have the SLP lid on my 02 SS. By the way nice car!!
quote:
1/ The filter is definitely not a blue K&N
2/ The filter is not an AFE
3/ The efficiency of the filter at 2.8 microns is 99%.
4/ The mesh that you have on your OE filter is not required with our type of construction. As long as it is the correct dimension and fits the air box.
5/ The difference in thickness is not the problem, as long as a filter has sufficient surface area for air flow and filtration for the specific application. A paper filter requires more area as it flows less per sq. inch than cotton gauze so they are thicker.
6/ An ACCEL filter is constructed with sufficient area using Galvanized steel mesh which makes it very rigid and resists implosion.
7/ There are many theories about pleating depth and shape, we use a normal pleat with sufficient depth to provide air flow and filtration requirements to give maximum performance and maximum filtration.
ACCEL filter material has been tested and certified by TUV in Germany. This is one of the most stringent testing bodies in the world, products certified by TUV are known to be of high quality and well tested. As far as I am aware there is no other performance filter that has been through this rigorous testing procedure and has been certified to this high standard.
ACCEL has a very efficient R&D department at our facility in Cleveland where we develop new filters and intake systems and are always looking to improve our products for our customers.
Still waiting for the one for my '01 GMC truck from Jegs, may also get one for my '93 Lumina grocery getter.quote:
Maybe they're made by Air Flow Engineering? (AFE)
Just noticed this one. As a safety systems engineer, I happen to know that TUV approval, in and of itself, is a useless benchmark. You have to see the entire TUV report to know what the "approval," is in relation too, and what the exceptions are.quote:
