Hi Everyone,
I did some work on my 2001 Honda Odyssey. In my repairs, I removed both front brake calipers, and the passenger side cv axle. When I put everything together, my abs and tcs lights were on. I was able to pull 2 codes: 31 (Hydraulic Modulator Solenoid Valve right hand front) and 34 (Hydraulic Modulator Solenoid Valve left hand front).
I looked around, thinking I bumped some wires in that area. There are not a lot of wires in that area, so no luck. The abs and tcs worked before I worked on it. Any ideas where I go from here? A light was left on overnight, so I have a dead battery when I got out in the morning. Would that have affected the system?
Thanks for any help you can give.
Brad
Brad
