- Joined
- Feb 22, 2021
- Messages
- 922
Watch: JetBlue Pilot Had To Force A Tailstrike To Avoid Hitting Beechcraft King Air
The pilot thought the oncoming plane would be landing from behind them, not head-on.
simpleflying.com
No benefit. It’s not mentioned anywhere by Airbus, for obvious reasons ( dangerous ). Probably panicked like KLM Captain in Canary Islands, who tried to rotate early to avoid the Pan Am B747 in front of them.The article is written like the JetBlue pilot did the tailstrike on purpose. "A JetBlue pilot performed a tailstrike to get airborne as quickly as possible" to avoid hitting the oncoming traffic. A tailstrike isn't really a maneuver, it's something that happens inadvertently.
Is there any performance benefit in the Airbus to rotating 25kts early and yanking the stick back so you hit the tail?
I wondered that too. Maybe the captain assumed the King Air that was 2.27 NM away wouldn't see him. However, the Airbus could have easily gotten turned off the runway before the King Air got there. Panic might be the correct feeling the captain had at the time.Not sure why they wouldn’t have rejected if trying to rotate 24 knots early
Looked like a panic move to me. Started the roll, realized that the traffic was in front of him. Panicked. Planted the stick full back.I wondered that too. Maybe the captain assumed the King Air that was 2.27 NM away wouldn't see him. However, the Airbus could have easily gotten turned off the runway before the King Air got there. Panic might be the correct feeling the captain had at the time.
Flying similar, but different , planes.When I was taking off in the 757 SIM, the first rotation was too slow, but I followed the FD to the correct pitch and all was ok. @Astro14 said something like, "3° rotation/second is where you want to be". The second takeoff rotation was higher than 3°/second, considerably higher, to which my trusty copilot said something like, "something closer to 3°/second would be a lot better, that was a bit aggressive". The 757 is considerably heavier on the controls than the 767, which is a light as a Cessna 172. I was trying to find the feel of the rotation and think I found it the third time, much closer to 3°/second.
Well said.Looked like a panic move to me. Started the roll, realized that the traffic was in front of him. Panicked. Planted the stick full back.
Hailed as a hero for his bad situational awareness, poor decision making, and panicking response.
It seems like there isn't much that they don't log and analyze. Is it a company bulletin saying, "hey you guys, there have been some aggressive rotation rates lately, use a lighter weight when you go to the gym"? Or, is it a personal bulletin, "Captain Smith, we were analyzing the rotation rates on your last 25 flights and you need to chill a bit on the weights at the gym"?Company monitors rotation rates and issues bulletins at times.
Company bulletin.It seems like there isn't much that they don't log and analyze. Is it a company bulletin saying, "hey you guys, there have been some aggressive rotation rates lately, use a lighter weight when you go to the gym"? Or, is it a personal bulletin, "Captain Smith, we were analyzing the rotation rates on your last 25 flights and you need to chill a bit on the weights at the gym"?
Every flight at my company is monitored by a digital recorder (not the flight data recorder, which runs continuously and is hardened for crash, but a separate device for our own internal analysis). It gets downloaded every day by maintenance and the data gets forwarded to an “event review committee” consisting of company and ALPA reps. Exceedences (like, flap limit speeds, rotation rates, stabilized approach criteria) and warnings are analyzed.It seems like there isn't much that they don't log and analyze. Is it a company bulletin saying, "hey you guys, there have been some aggressive rotation rates lately, use a lighter weight when you go to the gym"? Or, is it a personal bulletin, "Captain Smith, we were analyzing the rotation rates on your last 25 flights and you need to chill a bit on the weights at the gym"?
That’s fascinating.Every flight at my company is monitored by a digital recorder (not the flight data recorder, which runs continuously and is hardened for crash, but a separate device for our own internal analysis). It gets downloaded every day by maintenance and the data gets forwarded to an “event review committee” consisting of company and ALPA reps. Exceedences (like, flap limit speeds, rotation rates, stabilized approach criteria) and warnings are analyzed.
An exceedence of note merits a phone call, at least, “Hey Captain, what happened on that morning arrival into Newark 22L, where you got 16 knots above target speed?”. An egregious event can lead to grounding, and retraining. For example, a GPWS warning going into Mexico City because of an altitude deviation.
It’s a non-punitive process that seeks to analyze errors, identify trends and correct behaviors through training.
All true and even worse, the captain had terrible situational awareness and the first officer must have resigned to authority and didn't say anything about taking off with head-on traffic. The King Air was correctly announcing their intentions and had the right of way. The two minutes until the clearance expired was a contributing factor, because the captain just had to get in the air before the clearance expired. Poor airmanship all around on the Jetblue crew's part.Looked like a panic move to me. Started the roll, realized that the traffic was in front of him. Panicked. Planted the stick full back.
True.All true and even worse, the captain had terrible situational awareness and the first officer must have resigned to authority and didn't say anything about taking off with head-on traffic. The King Air was correctly announcing their intentions and had the right of way. The two minutes until the clearance expired was a contributing factor, because the captain just had to get in the air before the clearance expired. Poor airmanship all around on the Jetblue crew's part.
