I'm starting this new thread separately from what I started yesterday evening as I jumped in on demarpaint's project... So some of you may have already seen some of this movie:
Rec'd my package of Kreen yesterday and am especially anxious to throw this in my daughter's '98 accord
Quick detail on the 4-cylinder 2.3L Accord:
* Purchased '09 with 150,000 on the odometer - not 100% certain of prior maintenance
* Mechanic replaced timing belt Sept '12 with 178,601 miles. Also adjusted valves
* Currently 187,650 miles
* Mostly driven on easy short-hops with occasional 140 mile highway trips - maybe twice monthly
* Car had a ticking at start-up (like a sewing machine) that would never go away - it DID lessen to a degree when warmed up. Not exactly sure when this started - might have always been there but this car was at college
* Car has had a regular OCI with filter (Fram Tough Guard) every 5,000 miles using M1 5W-30
* Replaced radiator at 175k miles - While at school, my daughter said it was leaking... not sure how bad the overheating ever got but, as of today, no cooling troubles at all.
* Car has been losing a qt of oil every 1,000 miles for about a year - since about 175k miles.. no leaks anywhere and no smoke out of the exhaust. Oil just goes away.
* Last oil change, 187,300, new filter (Fram Tough Guard) and Penzoil HM 10W-40.. I jumped to 10W-40 in an effort to negate the oil loss
* The ticking has pretty much gone away and been replaced with a more pronounced knocking. No knock at start-up but after a minute or 3, gets somewhat louder. Doesn't seem to diminish with a warmer engine and never gets really loud - but it's there
* My feeling is that the knocking might be a result of the heavier 10W-40 oil...
* 50 miles ago, I added 1 qt of MMO. The MMO diluted the oil somewhat but the knocking is still there and it's driving me nuts
Now for the new stuff:
I popped the valve cover off and dropped an oz of Kreen into each spark plug well - it's out there now with a cloth covering the head. Took a 19mm open end and have been turning the power steering pulley every once if a while to shake things up a bit. I'd like to leave it soaking overnight
Here are a few pics of what the car looks like with the cover off:
My plan going forward starting today
1. Let the Kreens continue soak - several more hours if not overnight then drive a few miles - very few around town to purge the Kreen. Is this a wasted step?
2. Drain the 10W-40 Penzoil HM and replace with spec'd Penzoil 5W-30 HM and either a Fram Tough Guard or Purolator One filter... Any suggestions?
3. Run the fresh oil for 50 or 100 miles to get the juices flowing
4. At this point, odometer reading will be around 187,700 and I'll add the remaining Kreens (roughly 28 oz) to the 4.5 qt sump
#4 is where I get a little nervous. I honestly expected to find more gunk under the valve cover and, although I'm excited to do this, I don't want to clean the car to death - kill it with kindness as my father used to say.
I recall dermapaint lessening the dosage during his Kreen test and am thinking I should consider the same approach?
On the one hand, a full dose could give me a mirror finish (kidding). But it would provide for a serious cleaning. On the other hand, a partial dose would allow me to save half a bottle and give it another run through
I'm on the fence here
Now - let's hear what you experienced folks have to say/offer...?
