Trying to find a good process to clean out my engine of old oil sludge and carbon deposits and not harm the stem seals.(250,000 miles) Pulled the valve covers and their totally caked with crud. Engine smokes at start up too. Compression check shows all cyls at 110-120psi(within specs)except #5 which is at 90psi. No ring noise or obvious piston slap. Some small ticking on (passenger side)opposite bank as #5. Very little oil consumption.
Will a strong motor flush be the first step? I've heard a quart of high detergent ATF added to the crankcase will work wonders for breaking down sludge too. I plan to manually clean my V covers first before the the treatment and then cleaning the pan afterward. Is Maxlife 10w-40 a good choice after a treatment? What filter is best? I'll change my PCV too at the same time. I suspect the seals may be bad, but hope things may improve some and the smoke will cease. Could I have better luck with Seafoam, Auto RX or CRC Motor Flush? I need some expert advice on this. Last resort is a complete valve job.
