So we have a 97 expo that has a remote start system. It also only unlocks with that fob and if the battery dies in the fob, the truck won't start. " If the alarm/horn relay clicks under the column "
the truck will lock itself if someone parks next to you or walks by if you don't lock the doors yourself. " Like when you walk up to the truck to leave for work "
So I tried the standard fob programming thing, 8 key cycles makes the truck go into programming mode. No normal Ford fobs will link up.
This truck is a hunting truck and wife's daily driver. I've come to terms with needing another fob or not having it in general. I'm open to just removing it if someone can she'd light on how to go about removing it from the Ford wiring. If somehow it's easier to wire a different brain into the truck so that it only locks the doors and doesn't cripple the truck that would be great too...
Can anyone guide me in how they are wired into Fords security? I feel like the truck should be kinda common but I just might not be looking up the correct questions.
