No keypad. The problem is, I currently do have remote keyless entry. It works. I’m just trying to add an additional key fob.
is this a factory remote keyless entry, with a factory ford remote?
The location of the module is behind the LEFT quarter panel (C455, C456, C457) about half way up the the left side wheel well behind the panels.
you have to jump 2 wire pins with paper clip on the program connector. The program sequence is this:
1. Turn ignition to RUN or ACC.
2. Momentarily jump pins in programming connector located in left rear quarter panel area (Connector will not be plugged into anything, it will have two pins inside it, if you have to unlug it you have the WRONG one. Not all vehicles are set up from factory for keyless remotes) All doors will lock then unlock to confirm programming mode.
3. Press any button on first keyless remote. Door locks will cycle to confirm programming.
4. If programming a second keyless remote, press any button on second keyless remote.
5. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
the factory key fob and module look like this:
Keyless entry was a option in 1994 for a cool $215... On the 89-95 cougar/thunderbird vehicles, the remote keyless entry came with the factory keypad on the drivers side exterior door, 1996 and 1997 DID NOT have the keypad. IF you do not have the exterior keypad on a 89-95 vehicle you did not have factory remote keyless entry as they came packaged together, and again the location of said RKE box is just ahead of the fuel pump cutoff switch behind the carpet on the left side of the trunk..
The Factory remote FCC ID is: GQ43VT4T p/n: F5DZ-15K601-B
