After reading most of the threads in this section it sounds like I should switch to Rotella from Yamalube. Looks like factory specs say SAE20W40 for temps to 32 degrees. While it is driven below that a few mornings a year doesnt happen often.
So which product and weight should I use? How often should I change it.
Any good filter that I might find at a local store or national chain?
Last what would be a great final gear and differential oil to use? Manual says SAE80API "GLY-4" Hypoid for final and either SAE80 or SAE 80W-90 "GL-5" Hypoid gear oil for L.S.D. Not sure I understand this... can I use the same lube for both chunks?
Appreciate the advice guys!
