- Joined
- Mar 20, 2025
- Messages
- 102
I highly suggest asking this in the powerstroke.org forum. There are many knowledgeable 6.7 minds in there.
Is the tech a trained diesel expert? There are some around but not every mechanic is. diesel expert.Update to this thread. Had the injector and pigtail replaced for P1555. Got a bad injector replacement and replaced again. All runs good but after every shutdown and restart P1555 keeps coming on. Tech believes PCM is the problem. Truck runs fine and only presents check engine light upon restarting which I immediately erase with my Scanguage and doesn't come back on until truck is restarted...strange.
Anyone have any knowledge or experience with this? They quoted $1,200 to replace and refresh a new PCM.
Take care.
Yes, an independent diesel shop.Is the tech a trained diesel expert? There are some around but not every mechanic is. diesel expert.
Appreciate it. Will reclean battery connections to rule that out. I am hoping all that was done. I'll have to look into that to verify if cleaning batteries doesn't help. Will keep thread updated on this. Very much appreciated all.Have they load tested all the injector wiring for that cylinder injector? They need to make sure pin drag is good on the pcm connector. Unlikely pcm is the issue.
There is most likely a wiring issue, a pin fitament issue or a ground problem.
first thing I would do is clean all pcm/chassis to battery grounds.
I would also ohm out that entire injector circuit from the pcm connector. Depending on what I find I’d do a temporary overlay of the wiring right to that injector and de-pin those 2 pins at the pcm connector and drag them across the terminals at the pcm to make sure they are making good contact. The tech should be able to find the problem doing these steps pretty easily.
Between the two places...I assumed they did. Planet Ford in Spring, TX (P1557 code) has a dedicated truck center...but I don't know. Shop tech said (non dealer - P1555) said he ran a bunch of tests and couldn't do one due to it being a Cab & Chassis. All was functioning good. When I get back home I need to call shop and see if I can get confirmation on all that was done. Will keep thread updated. Appreciate all the help and advice.Did they check all the wiring?? It sounds like that dealer is just a parts changer and has no idea what really is the problem
emissions. ULSD was the start of lubricity failures in every aspect of the diesel world.I don't know why some manufacturers just can't seem to make a reliable diesel anymore.
I like the 8.3 swaps they do with the f-450semissions. ULSD was the start of lubricity failures in every aspect of the diesel world.
i ripped out my garbage 6.7 and stuffed in an old school used 5.9 cummins with 700k on it before the swap, even comes with auto-drip rust guard for the truck frame. Half it's diet isn't even diesel fuel. I won't post exactly what so the tree huggers won't flip out. And no, not biodiesel.
I may need to research and make sure they still use bio diesel. I asked the tanker driver at buccees, and he said it's in there a while back. Uses to use standalone lubricity formula and nothing made the truck run as smooth as that stuff. I quit using it because the bio diesel is supposed to be betteremissions. ULSD was the start of lubricity failures in every aspect of the diesel world.
That 6.9 will do what you need and get you where you are going but you will always be late.Yep.
I'm keeping all of my old school 1 wire fire diesels. Built a small building to house them all. Same with all the manual gearboxes, xfer cases, and PTOs.
Blue tip wrench ajd some 240v hot glue sticks is all I need to do a swap.
Currently stuffing in an old 6.9 IDI into a nice southern 2018 f350 long frame.
She's gonnna have a regular cab, with a 12ft box, 8ft wide, and 4ft tall, and hydraulic dump from the PTO hanging on the side of the BW. None of that electric/battery bull sheet.
Something useful that lasts that isn't available. Quite the combination.
Disgusting spending $100k+ on a diesel that doesn't last, choked to the point it destroys itself, then an electric dump hoist??? Turn that pump off the crankshaft like a real man.
Good god. What's the manufacturing world coming to??? "Real" trucks have at least 3 sticks poking out the floor. Gearbox, xfer case and PTO.
Only people I've noticed in life who are in a hurry are the race boys and SEMA weiners.That 6.9 will do what you need and get you where you are going but you will always be late.
I really feel you have a wiring issue or ground problem
Many times in situations like this, resistance checks are not enough. The wiring must be load tested, and the pins on the connectors must be drag tested outside of the connectorAppreciate it. Let me find another shop and arm them with this situation...maybe they can take a more targeted approach based on what is happening. The last tech said he checked all grounds and wires, etc. Don't know about exact diagnostics though. Either way, will keep everyone updated. No trips planned for a while so need to get this figured out. Thanks again Mattd...you have helped me in the past with your knowledge. Thanks for your time and knowledge. Happy 4th all.
Resistance checks are not enough.
