Originally Posted By: JOD
Originally Posted By: modularv8
Optimum Viscosity Grade
Just in reading the first 2 sentences in that book, there are pretty blatant half-truths and weasel words that make me question the objectivity of the author right off the bat:
-he states that decreased viscosity leads to increased consumption (while true in theory, in actual practice the difference in many engines is negligible, to the point where an owner will never notice; and secondly, an increase in consumption isn't necessarily a bad thing)
-he then states that lower viscosity "may lead" to increased engine wear "up to" 30%. This is pretty much the ultimate in weasel wording. While it may have a factual basis (I don't know, because I don't see the basis behind it) , in actual practice it's a totally specious claim if lower viscosity oil is used in a car for which it's specified.
I also have to wonder if the manufacturers specify a "minimum" HT/HS, what variability do they allow? I simply can't believe they're specifying an oil at the exact edge of acceptability, since it's known the oil is going to shear during its service life.
As far as Ford is concerned, they don't specify a variability but a minimum HTHSV of 2.6 cSt. Some OEMs are better at design, QC, and tolerances and their engines hold up better. In general, getting down below the minimum stated HTHSV specified for a particular engine may cause problems (some without notice over time, but gradual). I believe the author is trying to encompass the general in regard to engines. However, the ideal operating viscosity of 9 to 12 cSt @ 100C in an engine is well known.
Quote:
Keep in mind, I'm not questioning your experience--if you're finding the oil is shearing to the point of effecting performance, I think you made the right call in changing it. I do think another option would be to look for a more shear-stable, thicker 20W oil, though.
Exactly what I have done. Just sharing my experience and knowledge for others.
