-54C Pour Point and high PAO content
USA
Is a pour point of -54C a fingerprint for high PAO content?
Please post links or reprints of MSD-sheets from the past if anyone has access to them. I want to see how many older/ current synthetics had -54C as a pour point. Then I'd just like to have a civilized discussion about it. That's all.
I know GC is still at -54C and everyone claims it is a high PAO based oil. I believe a lot of the older Mobil 1 oils were also -54C but I can't find any MSDS from the past.
Let me clarify:
- I mean exactly -54C. Not -53, -65, -48 etc.
- "lower" being a larger negative number so that -75C is lower than -54C. Higher obviously the opposite.
- Not interested at all in how pour point depressants can lower pour points beyond -54C. That is another conversation.
Speaking from experience... I ran Mobil from when my SUV was new until about 80K KM in the frigid winters up here and I never had lifter ticking or any cold-start problems that I have had with other synthetics. I know my engine is picky, but that should speak well for this oil.
It's excellent for cold weather application IMO, and has to have a good amount of PAO to achieve this I would think!
^^ your area would be a good test too one would think.
The Yukon... The company I work for has restaurants up in the Yukon and it gets very cold for extended periods like -50oC
i was a little nervous at first when the cold set in but oil pressure was always right there and not much ticking at start up,very very little then gone.
Let me clarify:
I've been running current fill viscosity since 2006. PDS from that time indicate -54C pour point. Current PDS doesn't list that parameter but AFAICT, formulation hasn't changed; only packaging and marketing strategy has changed for that product.
Exxon-Mobil Corporation wrote in 2006:
Quote:
Mobil 1 0W-30 Search Find an MSDS
Mobil 1 0W-30 Pdf
Advanced high performance synthetic engine oil Print View
Product DescriptionFeatures and BenefitsApplicationsSpecifications and
ApprovalsTypical PropertiesHealth and Safety
Product Description
Mobil 1 0W-30 is an advanced high performance synthetic engine oil
designed to provide outstanding wear protection and enhanced fuel
economy performance. Mobil 1 0W-30 exceeds the requirements of the
latest industry standards required by newer modern gasoline and
certain diesel powered automobile engines. Mobil 1 technology is
race proven and is the choice of race car drivers around the world.
Mobil 1 0W-30 is perfect for all types of driving anywhere in the
world and has the performance to protect where conventional engine
oils do not.
Mobil 1 0W-30 is made with a proprietary blend of ultra high
performance synthetic basestocks fortified with Supersyn Antiwear
Technology, the most advanced additive system available today. Mobil
1 0W-30, enhanced fuel economy formula, is uniquely designed to
provide unsurpassed levels of protection, especially at start-up in
the coldest environments for reduced engine wear. The oil meets all
of the industry standards for fuel economy, helping to save fuel and
reducing CO2 exhaust emissions. Key features and benefits include:
Features
Advantages and Potential Benefits
Active cleaning agents Prevents deposits and sludge build-up
to enable long and clean engine life
Outstanding thermal and oxidation stability Reduces oil ageing
allowing extended drain interval protection
Enhanced frictional properties Greater fuel economy
Excellent low temperature capabilities Quick cold weather
starting and fast protection
Extended engine and electrical system life
High Viscosity Index and Supersyn Antiwear Technology
Excellent overall lubrication and wear protection performance
for all driving styles and conditions
Applications
Mobil 1 0W-30 is recommended for all types of modern vehicles,
including high-performance turbo-charged, supercharged gasoline and
diesel multi-valve fuel injected engines found in passenger cars,
SUVs, light vans and trucks.
Mobil 1 0W-30 is especially suitable for extreme conditions, where
conventional oil often cannot perform.
Mobil 1 is not recommended for 2-Cycle or aviation engines, unless
specifically approved by the manufacturer.
Back to Top
Specifications and Approvals
Mobil 1 0W-30 meets or exceeds the following industry
specifications
ACEAA1,B1
APISM,SL,SJ,EC,CF
ILSACGF4
Ford WWSM2C929-A
General MotorsGM 4718M,GM6094M
ChryslerMS 6395
Typical Properties
Mobil 1 0W-30
SAE Grade0W-30
Viscosity, ASTM D 445
cSt @ 40ºC 63.1
cSt @ 100ºC 11.0
Viscosity Index, ASTM D 2270 169
Sulfated Ash, wt%, ASTM D 874 10
HTHS Viscosity, mPa·s @ 150ºC ASTM D 4683 2.99
Pour Point, ºC, ASTM D 97 -54
Flash Point, ºC, ASTM D 92 228
Density @15º C kg/l, ASTM D 4052 0.845
Back to Top
Health and Safety
Based on available information, this product is not expected to
produce adverse effects on health when used for the intended
application and the recommendations provided in the Material Safety
Data Sheet (MSDS) are followed. MSDS's are available upon request
through your sales contract office, or via the Internet. This
product should not be used for purposes other than its intended use.
If disposing of used product, take care to protect the environment.
The Mobil logotype, the Pegasus design and Mobil 1 with Supersyn are
trademarks of Exxon Mobil Corporation, or one of its subsidiaries.
3225 Gallows Road
Fairfax, VA 22037
1-800-Mobil25 (662-4525)
Due to continual product research and development, the information
contained herein is subject to change without notification.
Typical Properties may vary slightly. This product data sheet is based on
global product data sheets for use with products purchased in the U.S.
© 2001 Exxon Mobil Corporation. All rights reserved.
ExxonMobil Home | Help | Sitemap | Contact Us |
Privacy & Legal
how's your 030 been doing? i have very little usage and great resualts from using it a year now.
It's doing great. I will not use any other oil in this car as it's HT/HS rating is slightly higher that that of Mobil 1 5W-20 but not as high as their 5w30.
I was always nervous about that rating in 5W-20; 5w30 was too thick as engine is rated for 5W-20 (2001 Ford 3.0L DOHC V-6).
Great oil.
Great oil.
I hear that.
Originally Posted By: chevrofreak
Mobil 1 10W-30 High Mileage is -54C
http://www.mobil.com/USA-English/Lubes/PDS/NAXXENPVLMOMobil_1_High_Mileage_Oil.asp
yup that why i had no issues running it through my MI winter this year.
I'm a fan of M1 HM 10w30 - but not in the winter months. Put a qt in your freezer over nite - it'll flow like honey (~ -10degF) - couldn't make it splash around in the qt bottle. I've also put M1 0w20 and PP 5w20 in the freezer over nite - stuff practically sounds like ice tea splashing in that qt.
Yea like i said was a little nervous at first,i had no problems
with it but i do think this winter 0w30 will be in the pan.
As someone who has run PP in the winter and cooler months, it's good but not as good as regular Mobil-1. I had lifter ticking for 5 minutes after starting my engine at -10oC with PP whereas I never had that with M1 even at -30oC
5w30 or???
