Originally Posted By: ZeeOSix
Then it would be safe to say doesn't protect any better, or they wouldn't advise bumping up a grade for tracking or heavy duty use.
Manufacturers recommend much heavier oil (ie, 5W-50) for track use because the resulting oil temps are usually much greater (especially without any oil cooler), which thins down the oil and reduces MOFT. Get MOFT too thin and engine damage occurs.
You could run 5W-20 in a track car all day long if the oil temperature could be kept cool enough with an oil cooler to ensure adequate MOFT.
I know, the operative word is "if, " if not then all bets are off. Lets not forget Ford changing spec to 5W30 from 5W20 recently in certain applications, as mentioned on this site. That's probably because MOFT with 5W20 couldn't be maintained and they might have feared additional warranty claims. The move to 5W30 might have fixed that, only Ford knows for sure.
