Originally Posted By: Fpm2026
Good morning, I’ve seen some posts about the eco boost engines and their beak in procedures. 2,000 miles at a semi synthetic oil then change to full synthetic from there on after. Is this the best and correct way?
Also I wasn’t sure if anything was different with the HO Ecoboost motor in the raptor in terms of OCI or break in that’s out of The ordinary . I was thinking of running redline 5w30 after my first oil change, but was wondering what my oil interval could be. I do not have the truck yet and was hearing the normal interval is 7-8000 miles with a motorcraft / mobile 1 full synthetic? I was wondering if the OCI would remain the same with redline. Or if not it would obviously be better to run such a great oil with with the turboed engine. I’m new to turbo engines also. as I was coming from a ram 1500 where I ran 5w30 Redline with Royal Purple Oil filter.
Is there anything I should keep in mind with a turbo engine? Anything to watch out for or make sure I am doing to take the best care of it. I plan on putting a lot of miles on this vehicle as I drive 20-25,000 per year.
Let the engine warm up before running it hard .Drive it easy for a few hundred miles them have at it not holding wot for long periods of time for a 1000 miles to be conservative, then have at it. Clean oil is happy oil. Let the engine idle down a few seconds and if running it hard for a bit longer as mentioned todays car turbos aren't like the turbo setups of previous generations.
enjoy the engine!
