2012-2014 Camry Allignment Specs
Upper Midwest by the Lakes USA
Anybody have the specs for the alignment range for toe, camber etc for a 2012-2014 (mine is 2013) Camry 4cyl SE?
I can tell that the camber is either a lemon on mine or they come from the factory with stupid amounts of camber in the rear.
Some amount of negative camber is necessary for handling.
Tires are a consumable item so get used to replacing them periodically. They really are not that expensive; for your SE it's probably $700-$800 every 40-50k miles.
Sorry for the blurry pic. Range is (-2.0* to -.5*)
Originally Posted By: GSCJR
I believe the rear camber is not adjustable for this model.
It might not have adjustability from the factory.
However, if it has Macpherson struts, you can buy a camber adjustment bolt so a mechanic can align the car. This is what I am used to seeing on Camrays. Independent suspensions without Macpherson are usually adjustable, but ones that aren't adjustable would need either a special replacement control arm, or bushing.
Must be something specific to the SE models with the wider wheel/tire combination.
My LE and XLE models don't show any rear camber/wear issues.
My first thought would be to check with the dealer; they should at least look at it for you. My 2011 Camry had rear toe that was a smidge out. I think Toyota's warranty on new car alignment is 1 year or 20,000 miles. Check it out in your owner's manual to be sure.
