Originally Posted by clinebarger
On GM vehicles with a 5-pin MAF........You un-pin the Yellow wire (MAF Signal Circuit) out of the MAF connector, Then plug the MAF connector back in.
The IAT sensor is incorporated into the MAF & needs to function as there is no good back-up strategy for erroneous IAT input.
Let P0101/P0102 set.....The engine will now run in Speed Density Mode, DO NOT clear the codes!!!
It's pretty straight forward......Unplug the connector, Pry off the Purple retainer, Remove the 2-tab lock on the back of the connector, Then lift-up the small plastic tab that retains the terminal in the connector....Then pull the wire/terminal out.
However.....Generally, There will be telltale signs of faulty/intermittent MAF readings, Like High/Low fuel trims!!
Originally Posted by The_Eric
GM 2.4s are notorious for failed vvt actuators also. When they go bad they do the same you're describing. First, check the oil level - if it's low they won't work right, if level is fine then most likely the actuator(s) are bad. They're cheap at the dealer - shop cost is like $35
Sorry for the late reply guys.
Touch wood but so far, after a few rains and car washes, the car has not acted up???
I have done nothing to it other than what I have mentioned previously. My son took my truck a few times to work a couple weeks ago when it rained or was raining out and when I took his car for some 10-15 minute drives or longer, I could not get it to stumble or stall.
I am not writing anything off just yet but maybe, just maybe, it was an anomoloy or something that somehow cleared itself up? Here's to wishful thinking anyways!!
I appreciate all the help/info that was provided.
