I have been using Alldata DIY for all the cars I maintain, but with my Subaru 2007 Impreza Outback Sport there have been changes and now a lot of conflicting information. For example, under cooling system service it said ad Subaru coolant conditioner, but the dealer told me that is for previous model years.
Anyway I changed the trans. with Subaru ATF @19K, 3.75 qts. drain and refill. At that time the dealer I was getting supplies from said don't bother with the filter to 90-100K mi. The normal service table back then suggested ATF change @30K. Now the normal service table just says inspect the fluid while the severe says change every 15K mi. Also now under procedure it says to drop the pan and change the strainer/filter, which has been revised with a new design using different length bolts and different torquing directions. Alldata lists the part # which I located on ebay and that sellers fitment checker says that part does not even fit my car. I asked a dealer parts person at another dealer about the strainer filter and he said he knows nothing about that, but said I should be changing the spin-on filter every time I change the fluid.
Does anyone know what I should be doing with this transmission? Again it was dumped and refilled @19K and now has about 38K.
