I have a 2005 Avalanche . I reworked the heads put in anew cam,lifters, push rods and timing set. I have a crank and no start condition. Fuel pressure is 50psi but my compression is only 55psi. I made sure when the timing set was installed I was at tdc. My cam and crank shaft gears were at 12 and 6. Where should I start when trying to locate why my compression is so low? Thanks.
