5.5 quarts with the OEM "shorty" filter, a full 6 quarts if you use an FL-1A equivalent filter (which I do on my 4.0s, and strongly recommend- I use the Pure One PL30001.)
The 4.0 is not a picky eater when it comes to oil, so it will probably be happy with whatever you put in it. The factory spec is 5w30 but a huge number of Jeepers, myself included, get great results (both scientific such as used oil analyses, and subjective such as engine "sound and feel") using 40-weight diesel engine oils. My preference there is Rotella T6 5w40, and I run it to at least 6000 miles (usually more like 7000 to 9000) with the large sized P1 oil filter.
The 4.0 talks a lot- its a noisy engine. You can hear lifter tick and piston slap routinely, but its not a problem. They just never gave it any sound-deadening valve cover or oil pan.
Your 2002 should be past the time when cylinder head cracking was more common than it should have been (2000 through mid-year 2001) so no worries there. You pretty much have a 300,000+ mile engine if you give it decent maintenance. 200k if you abuse the heck out of it.
Welcome to the world of Jeeps! Join JeepForum.com (or one of the others) if you haven't already. You'll have to wade through a certain number of kids asking what kewl light bar to put on, but there's also a lot of great nuts-and-bolts tech, too.
