Originally Posted By: clinebarger
That's Piston Slap. Some LS engines are really loud when it's cold!
Like Trav already stated......Fix the misfiring! Your going to ruin the converters if their not already the cause of the misfiring. A flashing MIL means the converters are being harmed.
These trucks generally set a P0101 "MAF sensor out of range/sensor performance" when the converter/s get plugged/partially plugged. But not 100% of the time.
Did you replace the plug wires?
Have the Catalytic Converters checked. You can make a Vacuum/Pressure gauge adapter out of an old O2 sensor.
Check Fuel Pressure.
Check for Fuel present at the fuel pressure regulator vacuum hose.
Spray some carb cleaner around the base of the intake (Where it meets each cylinder head) on a cold start.....If the RPM's change dramatically or makes it run rough, Change the Intake gaskets. They leak when is cold & will not necessarily cause "lean" codes.
Do you have a way to isolate the cylinders that are misfiring? Capable scan tool to watch/log misfire data?
While the Multec II injectors on your truck are not near as bad as the original Multec injectors......Their performance still degrades over time/mileage especially if it sits a lot. I think Trav checks & flows Injectors?
Exactly. I can't see how changing oil brands or grades, or filter brands is stopping a blinking CEL, and misfire.
Yes Trav has an injector cleaning business, and does top notch work! The two of you have pointed the OP in the right direction.
