2 yr old M1 0W-20 AFE. Still good?
USA
It's perfectly fine, but I suggest that you shake it up before you pour it in the engine in case any additives settled out. Check out Project Farm's videos, he has a couple videos on this subject
PA
How does oil compare with something like brake fluid which you're supposed to keep fresh since it loves absorbing moisture over time? Does it matter that it's sealed? Plastic is technically porous right? BTW OP I think you're fine with 2 year old oil. I'm sure some member here have oil stashes that exceed 5 year old oil sitting.
New York
Exxon Mobil says it should have a shelf life of five years. But people have used 20 year old oil here with no listed issues. Personally I think 7-10 yrs. is okay for sealed oil in a climate controlled storage. Blackstone did a a study once and found that oil from the 1960's still had additive in suspension, so IDK..
San Diego, CA
If it's sealed, it's fine. As someone else stated, shake it up first before pouring. If it wasn't sealed, then it's still ok, but maybe it has some more water, but shouldn't be an issue as it'll burn out anyway.
Bud
Texas
Originally Posted by MrQuackers
I've consumed vacuum packed apple sauce 10 years expired and it was delicious! Two year old AFE will be just fine.
Yes, but how about the taste?
Upper Midwest
I'm sure it was delicious too wink
In the shop
Originally Posted by jharrison
I have a sealed 5 qt. container of said oil. Is this still ok to use it? It's for a 2017 Civic.
If your worried, I'll pay shipping if you send it to me smile
Indiana
Originally Posted by tundraotto
I have used 10 year old, opened, half full oil stored in a garage without any care....maybe I'm doing it wrong...
Me too. I stocked up on that magic green Castrol, stored in a barn, and just finished it up last year.
Yup. I've weeded my stock out to right at the 5 year mark. I started with some from 2012 when I bought them in October. No issues.
Kansas
How much many jugs do you have. More than my 18 qts??
I done did choose this username for a reason. LOL
