The house we just bought came with the 2007 CC. It ran when we arrived but had issues starting...turned out the starter shaft was bent. Replaced it and it mostly fixed it but it still cranks hard hot sometimes ..looks like valves are probably out of adjustment. Kohler courage twin 23hp. Common problem along with the weak starter. So until I get the valves adjusted I'm using the old antique. I have to remember to close and open the fuel shutoff valve or it leaks it all onto the garage floor but otherwise it runs like new. I got the old girl from a guy I used to mow for when I did it as a side job. I also fixed it for him a couple times (despite my limited small engine knowl)..a battery, a starter and cleaning the ignition switch contacts (separate occasions over about 4-5 years). This old thing has been a tank. It came with the house he bought. Probably was at that house since 1981 when it was probably built.
