1994 Pontiac Grand Am 3.1L V6 automatic
AMSOIL Series 2000 0W30
3/4 Highway driving
SDF-29 oil filter
AMSOIL TS110 air filter cleaned at ~140k miles
Sample taken dec-12-2004
Added 0.5 quart of AMSOIL 5W30 at filter change - 7,474 miles into OCI.
12,504 miles on oil - 7 months
145,198 miles on car
Oil Analyzers, Inc. did the UOA
1st number: 12,504 milles (current)
2nd #: 18,331 miles S2K 0W30
3rd #: 2,920 miles S2K 0W30
Iron - 37/44/26
Chromium - 2/3/2
Lead - 21/23/6
Copper - 20/17/7
Tin - 0/0/0
Aluminum - 12/12/10
Nickel - 0/0/0
Silver - 0/0/0
Silicon - 76/144 abnormal/94
Boron - 31/25/5
Sodium - 245 abnormal/74 abnormal/216 abnormal
Magnesium - 874/457/162
Calcium - 2804/1796/1932
Barium - 0/0/0
Phosphorus - 1071/882/917
Zinc - 1224/1268/1322
Molybdenum - 14/13/38
Titanium - 0/0/0
Vanadium - 0/0/0
Potassium - 35 abnormal/55 abnormal/39 abnormal
Fuel 17.87 cst abnormal /16.80 cSt - abnormal/10.31
Water - 0/0%/0%
Soot/solids - N/A
Glycol - NEG/NEG/NEG
TBN - 3.38/3.02/6.31
Oxidation - 13.0/14.0/5.0
Nitration - 10.0/12.0/7.0
Oil was drained & oil filter changed when sample was taken. I added a bottle of AutoRX to the new GM 5W30 oil & will be doing a two bottle treatment. AC Delco oil filter will be used for the 1st couple of intervals.
My mpg had been suffering which I usually have with winter gas. However, I think it's due to the 50W oil in the crankcase!
Iron was 3.0/1000 miles.
Lead was 1.7/1000 miles.
Copper was 2.1/1000 miles.
Aluminum 1.0/1000 miles.
Silicon 6.1/1000 miles.
It would appear that I have yet another coolant leak? Did I get a bad intake manifold gasket?
The oil had tested positive for a coolant leak in what would be the 4th sample. The 3rd sample is right after I fixed the coolant leak.
I believe my silicon was lowered b/c the air filter was cleaned at 140,841 miles. It had 29,398 miles since it was installed new. I forgot to write it down to clean it & I forgot!
I usually add 1oz of Redline Fuel System Cleaner at every fill-up. Spark plugs were replaced during this interval. The coolant was flushed during this interval when the heater core failed.
I will be consulting Terry on this one as well.
UOA history: newest to oldest
Castrol GTX http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001379
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic&f=3&t=001378#000002
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic&f=3&t=001377#000000
Ideas besides not going more than 7500 miles (after the ARX) on an OCI? I will probably go to AMSOIL 5W30 & quit using the expensive AMSOIL 0W30. I may be ruining this engine by trying to do something that can't be done in this particular car. At least I gave it a good shot!
3/4 Highway driving
SDF-29 oil filter
Iron - 37/44/26
Chromium - 2/3/2
Lead - 21/23/6
Copper - 20/17/7
Tin - 0/0/0
Aluminum - 12/12/10
Nickel - 0/0/0
Silver - 0/0/0
Boron - 31/25/5
Barium - 0/0/0
Titanium - 0/0/0
Vanadium - 0/0/0
Water - 0/0%/0%
Soot/solids - N/A
