Originally Posted by dave1251
SMH tailor. It's going to bust at the seams with that molasses. Your going to need kerosene to thin it out.
At the very least, or build a fire under the oil pan.
aquariuscsm: I think the short OCIs have vanished; I can't say for all models. For the Q60 I tested, there was an OLM of some sort, not sure of its intelligence, as it were, but it was expected to go off at about ten thousand miles. So, that is where I do get a little wary. Don't make any real change to the oil spec, add a couple turbos, and triple the OCI.
Sure, it called for 0w-20 which will usually be a synthetic, or a 5w-30, which the dealer will upsell to a synthetic, but you know there will be those using 5w-30 conventional all the time, and if the oil life monitor isn't intelligent, I'm not sure if 10,000 miles each time on conventional with a twin turbo is feasible. They want to relive some late 1980s/early 1990s Audi problems, perhaps.
