L Linctex Joined Dec 31, 2016 Messages 10,142 Location Waco, TX Jun 15, 2017 #1 15W-40 $5.44/gallon ($10.88 for a 2 gal jug) Harvest King (Mid-States distributing) at Atwood's stores
SwampSurvivor Joined Apr 9, 2008 Messages 16,479 Location Central NY Jun 15, 2017 #2 $1.36 a gallon - wow!
SwampSurvivor Joined Apr 9, 2008 Messages 16,479 Location Central NY Jun 15, 2017 #3 $1.36 a gallon - wow! Wonder if it has higher zinc since it's only SM?
O old1 Joined Jan 4, 2011 Messages 1,227 Location Columbus Nebraska Jun 15, 2017 #4 That iS $1.36 per quart, but being that it is a 15/40 and only CJ-4 I would bet that it has a good high ZDDP level.
B beanoil Joined Oct 17, 2004 Messages 3,394 Location Midwest, Illinois Jun 15, 2017 #5 Good oil, although some will still avoid it because made by Citgo. 5 gallon pail currently at Rural King for 29.99 . And on the Ford approved list for PowerStroke, so you got that going for you. Last edited: Jun 15, 2017
L Linctex Thread starter Joined Dec 31, 2016 Messages 10,142 Location Waco, TX Jun 15, 2017 #7 Originally Posted By: Miller88 Wonder if it has higher zinc since it's only SM? Curious about that as well Originally Posted By: beanoil And on the Ford approved list for PowerStroke, so you got that going for you. That's what I was thinking.... The whole "CK fiasco"..... I got 4 gallons for $21.76 (farm tax exempt)
SwampSurvivor Joined Apr 9, 2008 Messages 16,479 Location Central NY Jun 15, 2017 #8 Whoops - meant quart, yes. $1.36 per gallon would be an even better deal!
S SZR48207 Joined Aug 15, 2008 Messages 4,962 Jun 15, 2017 #9 This could be used in a wet clutch motorcycle right?
L Linctex Thread starter Joined Dec 31, 2016 Messages 10,142 Location Waco, TX Jun 15, 2017 #10 Originally Posted By: Reddy45 This could be used in a wet clutch motorcycle right? Probably - -I put 80,000 miles on a 1999 Suzuki VZ800 Marauder running SuperTech 15W-40
L Linctex Thread starter Joined Dec 31, 2016 Messages 10,142 Location Waco, TX Jun 15, 2017 #11 Originally Posted By: beanoil Good oil, although some will still avoid it because made by Citgo. Is that per a current MSDS?
L Linctex Thread starter Joined Dec 31, 2016 Messages 10,142 Location Waco, TX Jun 15, 2017 #12 I found a MSDS for SAE 30 Harvest King - but it's from 2006: https://www.ruralking.com/media/blfa_files/Harvest_King_All_Fleet_Motor_Oil__SAE_30.pdf Last edited: Jun 15, 2017
S Syntheticuser Joined Jun 11, 2017 Messages 147 Location Waco, Tx. Jun 15, 2017 #13 Does the Atwoods in Bellmead have and good deals on synthetics?
L Linctex Thread starter Joined Dec 31, 2016 Messages 10,142 Location Waco, TX Jun 15, 2017 #14 Originally Posted By: Syntheticuser Does the Atwoods in Bellmead have and good deals on synthetics? Usually just Harvest King. I've gotten 1-gal jugs of full synth H.K. for $11 when on sale. It varies.
S SmrtJustin Joined Jun 24, 2006 Messages 55 Location Fort Wayne, IN Jun 16, 2017 #15 I uploaded a VOA of this oil just recently in the BITOG VOA section: https://bobistheoilguy.com/forums/ubbthr...40_#Post4414794 I was able to obtain a MSDS for it directly from CITGO.
