12 volt air compressor
What is the intended use?
I have a Ryobi cordless one I use a lot so I do not need to drag out air hose from compressor in garage. It also will shut off at a selected pressure and I like that.
But if you want to carry one in car then a 12V one is what is needed.
intended use is carry in vehicle
cordless would be nice, glad i thought of that
i will look at those, thanks D
I used mine again this weekend. 5 yr old. Works good. Bought another and it has 10 minutes on it, worked great. Plugged a flat, re-inflated in less than 10 minutes. No overheating on one tire. More than that it would need to cool. I would not do a semi tire at 100 PSI. It might get too hot. Great little compressor, much faster than the 10 dollar ones.
Rod
I have a Viair 400H in my trail Jeep. I've had it for years and it's been flawless.
Viair indicates it can inflate a 35" tire from 0-30psi in 5:20. My Jeep is a trailer queen now with 38x16's that only runs 3 PSI, but if I need air, it inflates them pretty quickly.
I got the next motor up from the one in your link for like $59 Plus the usual 20% discount. The motor/compressor rod has Ball bearings and a metal base-plate with rubber isolators so it doesn't dance around on the ground while running.
Viair 88P
I like this model specifically because it connects directly to the battery as opposed to relying on the 12V cigarette lighter.
It has excellent reviews on Amazon.
Originally Posted by CELICA_XX
Viair 88P
You are limited to xx amps out of the cigarette lighter (fuse) vs clamps to battery post.
Viair 88P
Ditto . It's a very stout compressor and it can pull more power.
I've had a few of those. I did modify them so they can connect directly to the battery. Otherwise they have a propensity to melt the 12V power outlet when inflating 4 tires. One died after getting driven over, the second died after inflating 3 sets of Jeep tires from 15 to 35 PSI and had a few years of hard use before that.
Right now I'm using this one: https://www.harborfreight.com/12v-150-psi-compact-air-compressor-63184.html , it's a few years old at this point but seems to work great. I hook it up to a manifold and inflate 4 tires at once. Gets hot, but I lube it every use. And it connects to the battery directly without modification.
I've got a Viair 88p and would recommend it. I like how it connects directly to the battery and the quality of the hose and the fittings. I throw it in the truck whenever I take a trip.
Originally Posted by John_Conrad
recomemdations for 12 volt air compressors?
any experience with this one:
https://www.harborfreight.com/12v-100-psi-high-volume-air-compressor-69284.html
I have this same HF Pittsburgh Compressor for my trunk/emergencies. It works well and does shut off at ~10 min to prevent overheating. And it almost filled a completely flat tire(225-70-15) but had to wait for the cool down.
