Originally Posted By: Shannow
Except "pour" testing was abandoned decades ago as the cold measurement for "W" gradings, as it proved to be too unreliable for actual engine starting.
If you need to know which oil will tip into your engine faster at 5F, then have at it with the freezer tests.
It was replaced with MRV, which is the ability of the oil to refill the oil pump suction pipework...that measure and that measure alone has a correlation with time to build oil pressure and fill galleries in test engines at extreme cold.
Yes. If you wish to start your car at low temperatures, then go by the W rating.
