Originally Posted By: wtd
I have a 2004 MC SS with the L67 3800. Does this engine have the same intake gasket problems as the non supercharged ones? These cars obviously use different upper manifolds so does the Supercharged ones have a manifold problem also? I just bought this car and the original owner had the coolant changed last year with the green stuff. Its getting a little wet on top of the intake near where the edge of the valve covers are so I'm not sure if what I'm seeing is oil or coolant. Its drying up from the heat so its difficult to tell.
wayne
If it's wet, stick your finger in it and see if it's coolant or oil. It sounds like intake manifold gasket though. Going back to green stuff from Dexcool can be bad mojo, too.
wayne
