Originally Posted By: Zee09
None of mine had that issue
The biggest Kohler I have is the 33 hp ( different animal) and the mowers manual- not Kohler
says that it is fine to mow at 3000 RPM and go up from there- I usually run around 3200 rpm for many reasons
and no issues doing so. If you purchased from a dedicated mower shop- they see tons of your model and they can quickly give you the scoop. I waited to run synthetic as on start up mine was smoking on my first engine at 55 hrs with FS oil and I had to dump the oil and go back to conventional and with that change the smoking went away quickly and after one hundred plus hours I did go back to FS-no issues at all.
Exmark required a 5 hr oil change and not the filter. I did it all and next time I'd leave the filter on as it was clean
with nothing in it. Most of these new mowers have the oil filter torqued to death. I use a long socket wrench or a breaker bar with
this tool- required usually..
I am using T5 10w-30 and @23hrs. It smokes a little during start-up & shutdown. Not visible but I can smell it. I checked the dipstick and still measures full. I changed oil&[email protected] (t5 & Fram ultra Xg3614)
My Kohler is a KT725 and the oil capacity is not 2.0qts but 1.8qts.
