in cleaning out the carbs on my outboard I broke off an idle mixture screw such that the remaining piece of the screw is in the carb. I have a new screw on order, so the problem is getting the old screw out without hurting the carb body or the threads. Need some advice.
The mixture screw is brass. The carb body is aluminum. This is on a small, brand new, yamaha outboard.
The screw diameter is about 1/8", maybe around a #6 in size, but metric. The screw stuck out about 1/2" from the carb to give you something to turn, but I broke that off and what's left resides about 1/8" to 1/10" below the surface.
My biggest concern is not messing up the threads in the carb body.
My thoughts, unless someone else has better idea, are to try in order:
1) either superglue or epoxy the broken off piece and hopefully have it hold just enough to unscrew it.
2) if that don't work try using a sharp hard steel flatblade to etch the screw so i can unscrew it with a flatblade screwdriver. hopefully the brass is soft enough i can carve just enough to use a flatblade?
.. thought about using a dremel cutoff wheel to carve a line but I think the screw is so small recessed to far so the cutoff wheel will end up carving the body and the threads. Plus i'd have to wear away a cutoff wheel from the 3/4" or 1" diameter they start out at down to about 1/8".
