I was hesitant to even post this, because around here this stuff is the holy grail second to GC. I bought like 6 bottles of ARX about 2 years ago and have treated 2 cars with it over that time.
here's an original thread from when things got started
http://theoildrop.server101.com/forums/s...true#Post291228
My little 2001 swift, which I previously posted results on
http://theoildrop.server101.com/forums/s...true#Post303465
that thread links to the first ARX treatment results. I also did a second treatment, and followed up with pictures. That thread was filled with bickering among people and from what I can tell, must have been deleted. (from my angle it feels like it might have been deleted because a believer in ARX might not want a thread floating around with proof that it might NOT work) but I highly doubt that is the case, I attribute it to the posts in the thread. I ask that yall keep it civil this time around, so we can have some useful discussion on this matter.
anyways... I finished up the 3rd full treatment, which got a heavy duty dose, (a full bottle ARX, instead of just 8oz), and ran it in the oil a little longer, (I think I left it in about 2500 miles)
This third treatment was actually finished up around September of last year, I took picts, but never got around to posting results. I'm kinda hesitant to show these results because I feel like I'm gona get flamed for doing something wrong (didn't do anything wrong BTW, used dino, used correct change intervals, didn't work, tried a reasonable alternative to beef up the 3rd treatment) I was already grilled on the last follow-up for methods, but since that was deleted (as far as I can tell) I can't prove it, lol...
Ok picts
before ARX
after 1st treatment
after 2nd treatment
after 3rd treatment
As I recall I used castrol GTX 5w30 for the first clean, and rinse, then I think it was castrol GTX 5w30 again for the second treatment, which I think I rinsed with 10W30 GTX and then used 5w30 havoline for the 3rd clean, and 10W30 havoline for the 3rd rinse. (this is from memory, it has been awhile, But I do know 100% that all clean and rinse cycles were done with common dino oils that should have been OK per the ARX instructions)
Since then, I did a run with delo-400 and a qt of MMO about 2500 miles, no change in cleanliness,
and right now I have a mix of aprox 2qts delo 400, 16oz seafoam, 16oz ATF, and 3/4qt havoline 5w30. have had that in for about 1000 miles, plan to change soon, I see no difference under there..
I want to try Bobs nuetra/ATF recommendation that we discussed around the time of the last update on this engine, but I can't find any sources to buy from around here...any suggestions on where to order it would be great, I really want to give that a try.
Ok picts
before ARX
after 1st treatment
after 2nd treatment
after 3rd treatment
