45904 Members
64 Forums
195336 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#792075 - 12/19/06 06:44 PM
6 point vs. 12 point socket
Loc: NE Pennsylvania
Other than the obvious, what is the difference between 6 point and 12 point sockets? Is one better than the other for certain things, or is it just a matter of personal preference?
#792076 - 12/19/06 06:46 PM
Re: 6 point vs. 12 point socket
[Re: Thorn]
Loc: Manassas, VA
As far as I can tell the only difference is that a 12-point socket is easier to put on the bolt you're removing.
6-point sockets are supposedly less likely to strip/round off the bolt. I have no 12-point sockets. I don't miss them.
#792077 - 12/19/06 06:47 PM
[Re: Thorn]
Loc: KY
I prefer 6 point sockets myself, They tend not to round off stuff as easily.
1985 F250 Ex-Cab 6.9 C6 2002 Dodge Caravan
#792078 - 12/19/06 07:14 PM
[Re: -Clayton-]
Loc: Las Vegas NV
All 6 points here. They make it almost impossible to round off a hex. Especially the shapes that Craftsman and Metrinch use. It also makes it more likely to grab a nut that is already rounded.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#792079 - 12/19/06 08:55 PM
[Re: Tempest]
Loc: The Motor City
When I started wrenching on cars 30 years ago, within a year I replaced my hand-me-down 12-pts with 6-pt impact sockets and never looked back. I'm still using the same set this day.
Only rarely have I seen a 12-pt bolt head -- mostly on aircraft.
This message written with 100% recycled electrons.
#792080 - 12/19/06 09:15 PM
[Re: Kestas]
Loc: Arkansas
6 point sockets put pressure on the flat of the fastener, where you can apply the most force. 12 point sockets put the pressure on the corners.
A 12 point can be easier to get on a fastener in a tight spot. I try to use 6 pointers as much as I can.
09 Torrent 3.6 V6 M1 0/30/40 09 Solstice 2.4 I4 Fram 5/30 08 G8 3.6 V6 Fram 5/30 04 Xj8 4.2 V8 Fram 5/30 99 S-10 2.2 I4 94 Xj12 6.0 V12
#792081 - 12/19/06 09:18 PM
[Re: Kestas]
Loc: snowblind in TX
Same here. The only 12pt I use is the 12mm for R&R of Ford driveshafts. I don't really even use chrome sockets at all anymore, except for 1/4" drive stuff.
#792082 - 12/19/06 11:06 PM
[Re: punisher]
Loc: ME
If you can't get a socket on something, spin the wrench a little. If you're using a cheater bar or torque wrench, pull the socket off and put it on the square peg 90 degrees off. This will offset the 60-degree hex 30 degrees from where you started.
#792083 - 12/20/06 04:50 AM
[Re: eljefino]
Loc: North Arkansas
Kestas and Punisher are dead on. Originally break over bars were used a lot. 12 point allowed for more "bites" in tight spaces. With the widespread use of ratchets, need for 12 point is nil. With exception of above mentioned drive shaft bolts and wheel bearing bolts on late model Dodge PU's.
Bob
To which version of reality would you like to convert me?
Bob
#792084 - 12/20/06 05:10 AM
[Re: alreadygone]
Loc: Everett, Washington
I concur with said info. Coming from my vast experience.............:) Well lets just say I have been around the block enough to know what they say is good info from my experience.
Beware the barrenness of a busy life. Socrates
#792085 - 12/20/06 05:57 AM
[Re: oilboy123]
Loc: Corpus Christi, Texas
I appreciate, too, the answers given.
With that in mind I would still pick up a 12-pt (quality; garage sale/pawn shop) in a size such as 9/16 where I seem to use it a great deal. I wouldn't go out of my way for it, but sooner or later that 12-pt socket will be handy.
2004.0 DODGE RAM 2500 QC LB Cummins 555 SRW NV-5600 14-cpm fuel cost last 37k miles
#792086 - 12/20/06 07:25 AM
[Re: TheTanSedan]
Loc: Santa Barbara, CA
ive only seen 12pt on Ford Driveshafts, the pinch bolts on some Ford Twin I-Beam bushings, and some dodge pickups. other then buying sockets for that specific reason, i have all 6pt. all my wrenches are 12pt though. i do alignments a lot, so i need to get into weird tight spaces on some really poorly designed suspensions.
2004 Volvo S60R 6 speed 1995 Ford Mustang GT 5 speed
Ford Master Parts Counterperson
"Fear disturbs your concentration." -Sabine Schmitz
#792087 - 12/20/06 05:19 PM
[Re: bdcardinal]
Loc: Michigan
Just to throw a "wrench" into this discussion.....the rounding of corners should be a moot point according to Snap-On, who I "think" first patented the 12 point socket that grabs the nuts (ouch) away from the corners. The patent must be elapsed because Craftsman and others now have this design.
Having said that, I also chose 6 point sockets on my last new tool set.
#792089 - 12/20/06 07:17 PM
[Re: blupupher]
Loc: The Motor City
Except for the Ford and Jeep driveshafts, I'm curious why the automakers don't use 12-pt fasteners more often like the aircraft industry does? It seems the auto industry prefers using torx heads for premium fasteners.
