Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
47 registered (09_GXP, 2015_PSD, AnthemBassMan, Al, 97f150, 5 invisible), 1053 Guests and 11 Spiders online.
58632 Members
66 Forums
252385 Topics
#486806 - 08/26/05 09:14 AM Oil Temperature for Air Cooled Engine
Slick Offline
Loc: Midwest
Any information on the oil temperature range for air cooled lawnmower engines at full load in 95 to 100 degree F outside air temperature.
Thanks Wayne
#486807 - 08/29/05 04:40 AM Re: Oil Temperature for Air Cooled Engine
JAYCEE Offline
Loc: East Texas
Using an air-cooled engine in this heat is severe service. You'll need to change the oil more often.
I'd use straight 30 weight for this application. "Delo 400 SAE 30" would be my first choice.
Stay away from the multi-viscosity oils in this heat. No 10W-30, 15W-40, etc.
#486808 - 08/29/05 06:09 AM Re: Oil Temperature for Air Cooled Engine
Gurkha Offline
Loc: India
I do use Delo 400 15W-40 on my Honda genset with good results, before moving to cool mountains, I used to live in Delhi where in the summers, the temps would come close to 48C and the genset ran in that heat for 7 hours straight without any problems.
The same Delo 400 as well as Delvac Super also performs admirably in 55C dessert of Rajasthan in my vehicles.
#486809 - 08/29/05 06:54 PM Re: Oil Temperature for Air Cooled Engine
1999nick Offline
Loc: Germantown TN 38138
I, personally, like to go by Briggs & Stratton's recommendations for any small lawnmower engine. It seems to be working fine for me. Their #1 recommendation is SYNTHETIC oil, in 5w30 or 10w30, for any temperature range. They do not recommend dino multigrades, saying oil consumption may result. They sell, under their own brand name, a 5w30 synthetic. They also recommend and sell 30w dino, for use in warmer temperatures.
I have a 2000 model Craftsman mower with the 5.5 hp Honda OHC engine. I have an hour meter on it to track usage, and it is used a little over 50 hours a year. After a 5 hour break-in, I used Mobil 1 5w30, changing once a year. It never used a drop in 4 years. This year, I had a quart of Mobil 1 0w30, so I used that. This oil now has 29 hours on it, and no usage as yet. The oil stays very clean, and I was tempted to use last years' oil two years. I wanted to see what the 0w30 would do, so I went ahead and changed.
I am convinced that lighter oils work best with the splash lubrication systems in most of these little air-cooled motors. Better distribution of oil when cold, less drag for a little more power and fuel efficiency. Heck, if I see no usage with the 0w30 this year, I may try 5w20 next year.
#486810 - 08/29/05 10:48 PM Re: Oil Temperature for Air Cooled Engine
JimG Offline
Loc: Dickinson, TEXAS
I recently installed an oil pressure gauge and a temp gauge on my 20hp Kohler engine (Craftsman tractor). I glued the temp sendor against the block (don't know how accurate that is, but it gives me a baseline). After running a while in 100 degree heat, I'll see 240F on the gauge. When I shoot the oil filter with my temp gun, I see 240-245F. Oil pressures run 35-40lbs.
BTW, I'm running 15w40 Delo and an ST8 Supertech filter, (yes it't big and it fits!)
Jim
#486811 - 08/30/05 09:04 AM Re: Oil Temperature for Air Cooled Engine
theguru Offline
Loc: Melb, Aus
A lawn contractor we use said that the honda 4 strokes seemed to not like the very hot days and said that Honda dealer recommended using under 35F.
#486812 - 08/30/05 10:23 AM Re: Oil Temperature for Air Cooled Engine
1999nick Offline
Jim
At first glance, I would say that your oil temperatures are running a little high. I just checked some add-on oil temperature gauges for cars, and about half of them showed a highest reading of 250 degrees. The other half would read as high as 300 degrees. I would try a 5w30 or 10w30 synthetic and see what the temperature is. A thinner oil should have less internal friction and run cooler, becoming less sludge prone.
#486813 - 08/31/05 04:10 PM Re: Oil Temperature for Air Cooled Engine
JimG Offline
Before I switched to 15w40, I was running 10w30 M1. Exactly the same temps. I'd rather have an HDEO in there.
#486814 - 09/01/05 01:34 AM Re: Oil Temperature for Air Cooled Engine
80caprice Offline
Loc: N.C.
its a air cooled kohler..right?... its not a car, it'll run considerably hotter, especially during hot weather....
#486815 - 09/01/05 04:15 PM Re: Oil Temperature for Air Cooled Engine
JimG Offline
Yes, it's an air-cooled Kohler V-Twin 20HP.
#486816 - 09/01/05 07:47 PM Re: Oil Temperature for Air Cooled Engine
burnout Offline
Loc: Endwell, New York
quote:
Thanks Wayne
I find it kinda funny how the first few posts had absolutely nothing to do with the question he asked :-P
#486817 - 09/01/05 11:25 PM Re: Oil Temperature for Air Cooled Engine
oilyriser Offline
Loc: Ontario, Canada
I've touched the crankcase of my lawnmower after using it on a hot day, with spit on my finger, and its'd definitely a bit over the boiling point.
#486818 - 09/02/05 12:11 AM Re: Oil Temperature for Air Cooled Engine
Bio-T Offline
Loc: London, AR
My John Deere runs at 200F in the crankcase with a 13 HP Tecumseh single cylinder using 0W30 GC.
Outside air temp was 102F. This was during and after mowing 1/2 acre. I would stop in the middle of mowing and raise the hood and take the reading immediately with my IR temp gun.
[Smile]
#486819 - 09/02/05 05:51 AM Re: Oil Temperature for Air Cooled Engine
Bill Kapaun Offline
Loc: Oregon
for those of you have have engines with oil filters, you can sometimes substitute a longer filter if you have the room.
This will add a bit of cooling surface
"Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass
Gasket 2.734"OD 2.430"ID 0.226" thick
Length" Wix Purolator Hastings Kohler B&S Baldwin JD TEC MotorCraft AC Fram
2.3" 57035 NA LF503 2805001 492932 B7165 ? 36563 NA NA? NA
2.7" 51056 L35310 LF302 1205001 492056 B1410 AM125424 36262 NA PF2210 PH8172
3.4" 51348 L10241 LF157 5205002 491056 BT223 AM101207 ? FL793 PF53 PH3614
#486820 - 09/02/05 04:26 PM Re: Oil Temperature for Air Cooled Engine
JimG Offline
A Supertech ST8 (PH8 in Fram, BIG FILTER) fits just fine on my Kohler, and at least twice as big as that little (expensive) Kohler filter.
BTW, if you do not own an infrared temp gun: BUY ONE! They are great for taking the guess work out of estimating engine temps. I just shoot the filter, instant gratification! They are down to 40-50 bucks now. I also use them for shooting marine exhasut manifolds, a/c registers, etc...
