Motul xcess 5w-40 vs Castrol edge 0w-40
Greece
which one do you prefer?
i think they are both Group iv...
( i wanted to use mobil 0w-40 new life,but i found out it is Group iii)
http://www.opieoils.co.uk/pdfs/castrol/EDGE Range/castrol-edge-0w-40-a3-b4.pdf
http://www.opieoils.co.uk/pdfs/MOTUL/motul-8100-x-cess-5w-40.pdf
what concerns me,is that castrol states that this oil is for high reving engines(so it has to be thick at operating temp) and i am worried it might have an impact to fuel consumption comparing to the xcess that is not so "racing" oil..
any opinions?
The Castrol 0w40 sold here is very light, HTHS of 3.6. The Motul is 3.7 and M1 0w40 is 3.8
There will be no difference in fuel economy.
M1 would be as much a group iv as the Castrol. I have no idea about the Motul. I would choose M1 if the price were the same only because I know more about this oil and what to expect when using it.
High RPM oil need not be as thick as low rpm oil (if there is such a thing)
You are worried about thickness, you obviously know that Mobil 1 is lighter than these two oils. Yes, it's group 3, but, in my opinion, is not a problem. It still remains a great oil.
However Castrol 0w40 FST and Motul X-Cess 5w40 looks quite similar to me...but unfortunately the HTHS value of the Castrol is unknown.
I have seen a lot of good analysis reuslts on the X-cess 5w40 in high-performance Audis (S4, S5, etc).
what's your opinion for,
motul xcess vs valvoline 5w-40?
i know that motul is Griii..Do you know what the valvoline is?
which one do u prefer?
i find this 2 at the exact same price..
valvoline
SynPower motor oil
SAE Viscosity Grade 5W-40
Viscosity, mm2/s @ 100 ºC.
ASTM D-445 13.8
Viscosity, mm2/s @ 40 ºC.
ASTM D-445 80
Viscosity Index
ASTM D-2270 178
Viscosity, mPa.s –30°C.
ASTM D-5293 TBN, mg KOH/g
ASTM D-2896 11.6
Pour Point, ºC
ASTM D-5950 -45
Specific Gravity @ 15.6°C.
ASTM D-4052
0.853
Flash Point, COC, ºC.
ASTM D-92 222
motul
Viscosity grade SAE J 300 5W-40
Density at 20°C (68°F) ASTM D1298 0.850
Viscosity at 40°C (104°F) ASTM D445 86.2 mm²/s
Viscosity at 100°C (212°F) ASTM D445 14.2 mm²/s
HTHS viscosity at 150°C (302°F) ASTM D4741 3.73 mPa.s
Viscosity index ASTM D2270 170
Pour point ASTM D97 -36°C / -32.8°F
Flash point ASTM D92 230°C / 446°F
Sulfated ash ASTM D874 1.09% weight
TBN ASTM D2896 10.1 mg KOH/g
valvoline
SynPower motor oil
ASTM D-445 13.8
ASTM D-445 80
Viscosity Index
ASTM D-2270 178
ASTM D-2896 11.6
Pour Point, ºC
ASTM D-5950 -45
ASTM D-4052
0.853
ASTM D-92 222
motul
anyone/?
