CastrolŽ EDGEŽ. Proven Stronger.
by bigt61
8 minutes 40 seconds ago
i think i have some type of virus.
by bowlofturtle
17 minutes 42 seconds ago
New Mazda3 'Skyactive'
by pbm
31 minutes 34 seconds ago
Castrol's new commercial
by coolbird101
36 minutes 5 seconds ago
Fw1 spray
by dslofti
39 minutes 58 seconds ago
Slime & dryrot
by Donald
54 minutes 30 seconds ago
2008 Nissan Frontier - Shock Recommendations
by TWG1572
Today at 07:26 AM
Synthetic Oil
by tauble
Today at 07:00 AM
Rislone
by GreeCguy
Yesterday at 11:54 PM
When did they add additives?
by GreeCguy
Yesterday at 11:25 PM
89 F150. QS Defy, Motorcraft syn blend, Rotella
by snowflake
Yesterday at 10:33 PM
Some new Auto 7 brand parts for my Hyundai -PICS-
by stephen9666
Yesterday at 09:10 PM
tauble, Markl50, Torox, kroeger, c24k
45446 Registered Users
101 registered (99Saturn, 147_Grain, alan_mac, 04SE, 2010_FX4, 2009Edge, 8 invisible), 1419 Guests and 249 Spiders online.
45446 Members
64 Forums
193586 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#2609299 - 04/25/12 11:06 AM How good are Energy Suspension components?
Loobed Offline
Loc: Northern California, USA
Are the components from Energy Suspension good? Are they better than OEM replacement parts? About 20 years ago when polyurethane suspension components first started coming out, I saw a few leaf spring and sway bar bushing split (I think they were Rancho parts). They split a lot sooner than the factory rubber ones they replaced. Have the polyurethane components gotten better and will they last as long as stock parts (10+ years or 100k+ miles)? How much better or worse is the ride quality? This is for a 2001 GMC truck, and I don't do any heavy off-road driving. I am not really looking for handling improvement. I want something that is as good as, or better than, stock, but for the same cost or less.
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2609307 - 04/25/12 11:14 AM Re: How good are Energy Suspension components? [Re: Loobed]
Hokiefyd Offline
Loc: North Carolina
I've used a number of their products, from a complete polygraphite front bushing kit, to greasable polyurethane sway bar bushings, to bump stops (all on separate vehicles).
I prefer rubber bushings in the control arms/leaf springs, but polyurethane (as long as it's greasable) on the sway bar. Ride quality with the polygraphite front bushing kit was horrible (and I eventually paid a garage to put it all back to rubber). But ride quality does not really suffer with the sway bar products, and handling improves.
The quality itself from every Energy Suspension product I've had as been very good.
#2609325 - 04/25/12 11:34 AM Re: How good are Energy Suspension components? [Re: Loobed]
dparm Offline
Loc: Lombard, IL
They're performance-oriented (typically) and are very good.
2011 Audi S4 sedan S tronic + Stasis exhaust & tune
Castrol Edge 5w40 + Mann HU722z
#2609333 - 04/25/12 11:41 AM Re: How good are Energy Suspension components? [Re: Loobed]
stephen9666 Online   sick
Loc: USA
It also depends what specific bushings you want to replace.
Energy and other companies offer poly bushings for applications they really shouldn't be used for.
For example, you can buy poly bushings for the lower control arms on my girlfriend's VW Beetle. But, poly bushings shouldn't be used for at least one of the bushings, because of the way the bushing needs to flex.
Long story short, do a little searching on a forum specific to your vehicle and see what people say. Just because you can buy a poly bushing, that doesn't mean it's appropriate for the job.
2007 Hyundai Sonata 5 speed <-- Unreliable
1999 Nissan Frontier 5 speed
2000 VW Beetle 5 speed (girlfriend's car)
#2609343 - 04/25/12 11:49 AM Re: How good are Energy Suspension components? [Re: stephen9666]
Loobed Offline
I need them for the sway bar end link, and I might replace the sway bar bushings as well.
#2609389 - 04/25/12 12:51 PM Re: How good are Energy Suspension components? [Re: Loobed]
mechtech2 Offline
Loc: Chicago Area
Sway bar end links are easy, bushings can be easy to strong cuss word producing [esp in the front].
Energy suspension bushings are very good.
Note that urethane should be greased - special lube is best, but use whatever you have instead of dry.
I like to dimple bushings for grease retention. Like a golf ball, only smaller concavities. A dremel tool with a round burr tip does this in a minute.
Rubber flexes, and urethane is a bearing -the part rotates in it.
This is why rubber suspension bushings like control arms should be final tightened with the weight of the car on the tires, and urethane should not matter.
Edited by mechtech2 (04/25/12 12:52 PM)
#2609404 - 04/25/12 01:05 PM Re: How good are Energy Suspension components? [Re: Loobed]
Loc: USA
I think those are appropriate uses for poly bushings, but I'm no expert.
#2609461 - 04/25/12 01:54 PM Re: How good are Energy Suspension components? [Re: Loobed]
yesthatsteve Offline
Loc: Kansas City, MO
I installed Energy Suspension sway bar end link bushings on the xB last year, as the original bushings showed quite a few cracks after 100k+. I've been pleased with the improved handling, but can't speak to how long they'll last.
'05 Scion xB, 135000+ miles
'01 Honda Odyssey, 230000+ miles, fourth transmission
#2609562 - 04/25/12 03:35 PM Re: How good are Energy Suspension components? [Re: Loobed]
dailydriver Offline
Loc: Bucks County, Pa.
As long as you do not over-tighten the end link bolts, and over-bulge/split the bushings, they last a LONG time.
Mine typically last >75K miles, even with sticky tires on wide wheels, and stiff shocks and springs, with both open-track and VERY rough pavement street use.
2000 Z28 1SC 6 speed 155K HARD miles!
5 qts. M1 5W-30 HM/1 qt. M1 0W-40/P1 filter (Kreen rinse)
Millers CRX 75-140 NT/4oz. XL-3, RL D4, RL PSF
#2609757 - 04/25/12 07:24 PM Re: How good are Energy Suspension components? [Re: Loobed]
ls1mike Offline
Loc: Bremerton Wa
I have them on the Trans Am, I have been pretty happy with them. Helped it to feel a bit more solid.
Mike
00 Trans Am
02 Silverado 2500HD
98 Regal GS
13 Equinox
12 Passport TT
Mobil 1
#2609776 - 04/25/12 07:46 PM Re: How good are Energy Suspension components? [Re: mechtech2]
Joe72Mart Offline
Loc: NE Ohio
Hi mechtech2
What type of grease is recommended? There was a recent thread, but not sure what the final verdict was. I'm about to purchase a 2001 SVT Cobra and plan to replace any worn bushings. I'd be buying the front sway bar bushings with the zerk fitting. Which "tube" for grease gun is best?
thx Joe
Edited by Joe72Mart (04/25/12 07:49 PM)
1970 Chevelle SS396/375HP
2002 Cavalier
1991 S10 Iron Duke 5sp W/T
2003 Corolla CE 38k miles NUMMI built by GM/Toyota
#2609797 - 04/25/12 08:06 PM Re: How good are Energy Suspension components? [Re: Loobed]
sciphi Online   content
Loc: Upstate NY
I put ES endlinks onto my old Buick. It made a nice difference in how the car handled. They proved pretty durable, too. I'd use their stuff again.
2009 Honda Fit Sport
2012 Chevrolet Cruze Eco
#2610027 - 04/25/12 11:46 PM Re: How good are Energy Suspension components? [Re: Hokiefyd]
Klutch9 Offline
Loc: Rochester, MI
I've used several of their products in the past, and have had problems with none of them. They make quality products from my experience.
'07 Focus 2.0 - 51,xxx mi - Havoline conv 5w-20
'11 Fusion 2.5 "Sterling" - 26,xxx mi - Service Pro blend 5w-20
#2610622 - 04/26/12 04:32 PM Re: How good are Energy Suspension components? [Re: Joe72Mart]
dailydriver Offline
Hi mechtech2
thx Joe
Prothane (and others) offer a polyurethane specific grease (clear, and VERY tenacious/viscous) in 14 ounce grease gun cartridges, but it is NOT cheap!! (>$36.00/tube!!! crzy )
#2612239 - 04/28/12 03:11 PM Re: How good are Energy Suspension components? [Re: Loobed]
mechtech2 Offline
Loc: Chicago Area
The 'right' grease is urethane sway bar specific. Good luck finding it in the first place.
I generally use moly chassis grease.
If you have zerk fittings, make sure there are grooves to distribute the lube all around. I still like my internal dimples - they are little reservoirs.
Page 1 of 2 1 2 >
