Supercharged Subaru BRZ
by clinebarger
07/27/16 07:52 PM
Side can opener ?
by ST2008
07/27/16 07:48 PM
Pennsoil ULTRA not available
by JXW
07/27/16 07:41 PM
2005 Civic randomly stalls when taking off from a
by Avery4
07/27/16 07:36 PM
2003 Saturn L200 oil choice
by car51
07/27/16 07:30 PM
Good hour meter for small engines?
by motor_oil_madman
07/27/16 07:07 PM
2001 Chevy S10 V6 misfire...
by Blang
07/27/16 07:02 PM
Oil level and rpm
by mjoekingz28
07/27/16 06:59 PM
Replacing vacuum breaker off external faucet
by Vikas
07/27/16 05:55 PM
Mobil1 EP 5W20 in Honda Accord
by alanwayne1908
07/27/16 05:46 PM
Grey color when wiping dipstick on VW VR6
by Guitarman200806
07/27/16 05:13 PM
Any audio gear junkies here?
by BeerCan
07/27/16 03:45 PM
uicgrad, snydercn, surfbum, Tmemz4, woollum86
58613 Registered Users
121 registered (addyguy, 09_GXP, 2015_PSD, AandPDan, AIRJAC3, Al, 11 invisible), 1875 Guests and 13 Spiders online.
58613 Members
66 Forums
252335 Topics
Page 1 of 2 1 2 >
#2593828 - 04/08/12 06:08 PM Sprockets JT vs Sunstar
Robenstein Offline
Loc: Central IA
Hey, just looking at doing a sprocket swap on a 99 Magna 750 for a friend. She bought it and the guy geared it for more acceleration, but it is getting horrible mileage now since she rides in out of town a lot. Got a new x ring chain for it, but I see that JT and Sunstar both make a decent selection of sprockets for it. Anyone ever have a bad experience with either? Looks like JT makes a few more options, but I thought Id see who here had some experiences with them on bigger bikes.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
#2593838 - 04/08/12 06:26 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
Quattro Pete Offline
Loc: Great Lakes
I am not liking the 17-tooth JT front sprocket that I got for my Vulcan. It dropped the RPMs as it should have (factory sprocket is 16T), but it causes more drive train noise and results in more vibration that can be felt through the footpegs. The JT one does not have rubber dampers built into it like the factory sprocket does. I am going back to the stock sprocket next week.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2593887 - 04/08/12 07:35 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
Robenstein Offline
Loc: Central IA
I have used both on smaller 250 cc bikes. The current ones on this bike are sunstar. I was also thinking of going up a tooth on my front sprocket on my Triumph.
1970 Chevy Nova
2006 Scion TC
#2593894 - 04/08/12 07:44 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
Trav Offline
Loc: MA, Mittelfranken.de
I have used them both in big bikes and had no trouble with either. Both went over 20,000 Km with and x ring chain which is good considering these bikes produce 165-185HP right out of the box.
#2594245 - 04/09/12 08:19 AM Re: Sprockets JT vs Sunstar [Re: Robenstein]
Smoky14 Offline
Loc: Nowhere NM
The biggest problem with cheap sprokets is not being tapered to allow smooth engagement of the chain. Some have a 90 angle between the side and the tooth tip and results in noise, and if not aligned can actually pull the counter shaft out of the case. You'd think it would break the chain first, but not in my experience.
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
#2595549 - 04/10/12 12:26 PM Re: Sprockets JT vs Sunstar [Re: Quattro Pete]
rrounds Offline
Loc: SACRAMENTO, CA
On one of my bikes I went up 2 teeth to 16 on the front sprocket(that is the same as taking 7 teeth off the back sprocket 14/48) and my rpm's went down as did any vibration I had in the foot pegs and handle bars. My gas mileage went up but I could not accelerate as fast in 5th gear(that is why they put 4,5 or 6 gears in bikes) All I had to do was down shift and off I would go.
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
#2595957 - 04/10/12 08:32 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
Mackelroy Offline
Loc: Florida /Texas
Sunstar is an OEM manufacturer, JT is not, while JT may be okay I've seen instances where they are not machined properly.
If you want precision guaranteed, SUNSTAR
#2596671 - 04/11/12 02:53 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
sunruh Offline
Loc: Cedar Park, TX
i've run sunstar. pretty decent. now i only run Ironman (also sold as MSR heavy duty) but they are not for all bikes make/models.
and of course part of keeping a sprocket alive is making sure the chain is perfect. which is its own can of worms.
motorcycle oil myth buster
#2597093 - 04/11/12 09:16 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
Robenstein Offline
Loc: Central IA
Normally Id swap the chain as well, but it has SUPER low miles on it. I think I will try the Sunstar and if its not enough for her I can drop a few teeth on the back with a JT.
1970 Chevy Nova
2006 Scion TC
#2597846 - 04/12/12 04:33 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
rrounds Offline
Loc: SACRAMENTO, CA
Here is a good site to play with your gearing and not cost you a dime.
http://www.gearingcommander.com/
ROD
'06 S2000
'08 Ford F53 V10
#2597922 - 04/12/12 06:13 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
Robenstein Offline
Loc: Central IA
Yeah the JT and Sunstar sites have gearing info on theirs as well. It does help though when making a choice.
1970 Chevy Nova
2006 Scion TC
#2598178 - 04/12/12 11:02 PM Re: Sprockets JT vs Sunstar [Re: Robenstein]
rraiderr Offline
Loc: Dante's Inferno
AFAM and Renthal make some stout sprockets.
We have had 0 issues with them at the track.
2015 GSX-R1000
2015 RMZ-450
2013 DRZ-400SM
#2599256 - 04/14/12 08:55 AM Re: Sprockets JT vs Sunstar [Re: Quattro Pete]
vortex9 Offline
Loc: Canada
I had the same experience with aftermarket sprockets. I went back to oem because of the rubber damper. It does make a difference if you spend a lot of time on the highway.
#2599989 - 04/15/12 06:44 AM Re: Sprockets JT vs Sunstar [Re: Robenstein]
Mackelroy Offline
Loc: Florida /Texas
Most the rubber damped OEM front sprockets are made by Sunstar, if you buy a generic sunstar it wont have the rubber dmaping.
Personally I always bought the oem fronts, and after market rears. I ran aluminum rears for 20 years. I went back to steel and the longevity is Five fold over aluminum, Like that iron man Sunruh mentioned.
But the weight savings of aluminum is not worth it, the longevity and your pocketbook will be alot happier with steel.
#2600836 - 04/16/12 09:13 AM Re: Sprockets JT vs Sunstar [Re: Robenstein]
sunruh Offline
Loc: Cedar Park, TX
yeah i run oem fronts and high quality steels back.
i can put 3 - 4 years of racing on a ironman rear where alum is about 1/2 a season. oh and get any kind of dirt/grim/mud/sand on alum and its toast!
Page 1 of 2 1 2 >
