45444 Members
64 Forums
193571 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2580252 - 03/26/12 01:53 PM
2003 Honda LX w/ neglected transmission
Loc: PL&F
Okay, guys. I'm helping some friends catch up on their vehicle's maintenance.
I believe the vehicle is around 150,000 miles on the original timing belt(different subject) and probably the factory fill ATF.
What would be the best C.O.A. moving forward? Do these Civic autos have a drain plug or is this a pan removal? Which fluid should be used to refill and should there be a subsequent drain/refill soon after?
Thanks.
1992 Civic VX 273k+ Coolant entry. Needs a hg job.
#2580272 - 03/26/12 02:13 PM
Re: 2003 Honda LX w/ neglected transmission
[Re: ltslimjim]
Loc: CT USA
Should have a drain plug. Would suggest drain and refill x 3. I drain the transmission through this plug and get about 2.5-3 quarts out. Refill with the compatible transmission fluid of your choice. I would use Honda DW-1. Drive about a week and repeat. Do this three times. You may find other recommendations for ATF but I haven't used them. Above all, do not power flush.
Good luck
Steve 2012 Acura TL 3.7L SH-AWD 20K miles Royal Purple 5w-20 SN Mann filter
#2580281 - 03/26/12 02:21 PM
[Re: ltslimjim]
Loc: New Jersey, USA
Thanks. Drain plug. If you look inward from the right wheel well, you can see a bolt with a 3/8" square hole. Open it up with a ratchet (no socket needed) and get ready for it to splash and pour out everywhere. Wipe the schmutz off the drain plug, put it back and refill only with Honda ATF-DW1. Unless you want to try something aftermarket, but I am too big a chicken personally. There's a Valvoline product and Amsoil product that are supposed to be ok in these trannies. You'll pull the yellow dipstick handle and use a long narrow funnel to refill. Should be between 2.5 and 3 quarts, but have a 4th on hand in case. Wait until the next weekend and repeat the whole process. I know it's a waste of fluid, but it's your only choice. You gotta get at least 3 drain and fills to have mostly new fluid, and 4 would be even better. Don't do them too too close together, or you'll never mix the new with the 3+ quarts of old that are in the torque converter. Easy job, but messy. You don't have to jack the car up or anything. Have fun!
2005 Honda Civic EX Coupe (Automatic)
#2580282 - 03/26/12 02:22 PM
[Re: ltslimjim]
Loc: PL&F
^Yes, ironic to mention 'power', though, as I think the PS system needs maintenance, too. Thanks for the reply.
#2580284 - 03/26/12 02:25 PM
[Re: ltslimjim]
Loc: Athens, GA
If its the I4 Accord there is no timing belt. They've got chains. And before anyone flames, yes the LX was available with the V6. Don't see many of those however.
#2580318 - 03/26/12 02:51 PM
[Re: ltslimjim]
Loc: New York
Shouldn't the filter be changed also?
2002 VW Jetta TDI. 179k RT6 2011 Toyota Matrix 29k 1998 Chevy Tahoe 268k M1 5w30 2000 GMC Sierra 0k RT6 1985 Fiat Spider 34k 1984 Nissan Turbo 81k 300ZX
#2580325 - 03/26/12 02:56 PM
[Re: ctechbob]
Loc: Virginia
If its the I4 Accord there is no timing belt. They've got chains. And before anyone flames, yes the LX was available with the V6. Don't see many of those however. It's a Civic.
2013 VW Passat SE TDI 6MT, 2006 Acura TSX 6MT, 2005 Toyota 4Runner V6 4x4, 2006 TJ Rubicon 6MT, 2001 Honda S2000, 1987 Chevy V10 350 700r4
#2580331 - 03/26/12 03:03 PM
[Re: JGW]
Shouldn't the filter be changed also? Nope. That would require removing and disassembling the transmission. There's no serviceable filter. It's a timing belt/interference engine. I'd get that taken care of right away, but sounds like the OP's already aware of this ticking time(-ing belt) bomb.
#2580354 - 03/26/12 03:15 PM
[Re: ltslimjim]
Loc: Waldorf, Maryland
The transmission drains only one-half of the transmission. If I were you, I would drain it , drive it for one week and drain it again. Use ONLY Honda Transmission Fluid.
Vehicles: 98 Corvette 06 Murano 96 Chevy Van (Custom Conversion) 10 Starcraft Boat 13 Buick Enclave
#2580378 - 03/26/12 03:35 PM
[Re: ltslimjim]
Loc: los angeles
What about disconnecting the pressure line that goes to the cooler? Drain it to a pan,turn engine on,let drain,turn car off,add atf to fill line,turn car on,drain,etc.keep doing this til it comes out clean.This should run through the whole trans and t.c. I did this on my Camry that had glittery brown in the oil.Been almost 2 years and no problems.Trans has about 220,xxx miles.
Edited by daves66nova (03/26/12 03:35 PM)
THIS SPACE FOR RENT, PLEASE PM ME.
#2580391 - 03/26/12 03:41 PM
[Re: daves66nova]
Loc: West Chester, PA
What about disconnecting the pressure line that goes to the cooler? Drain it to a pan,turn engine on,let drain,turn car off,add atf to fill line,turn car on,drain,etc.keep doing this til it comes out clean.This should run through the whole trans and t.c. I did this on my Camry that had glittery brown in the oil.Been almost 2 years and no problems.Trans has about 220,xxx miles. This question has been asked by me and MANY others here and on other forums. I also do the cooler return line deal on my 99 Avalon and 99 RX300 with great success. Honda strongly opposes flushing but no one seems to know if they are against only machine power flushes or the cooler return line flush that you are asking about. There was one person who seemed to be an expert who said the return line flush is ok but the vast majority say to stick with the multiple drain/fills just to be on the safe side.
#2580418 - 03/26/12 03:59 PM
[Re: ltslimjim]
Loc: Georgia
I don't see how the trans line method of replacing all the fluid could be considered a flush.
All you are doing is replacing the fluid, just like with the 3X drain and fills. And at the end of the day, you are left with fresh fluid compared to mixing old and new fluid with the 3x D&F method.
How can that be a bad thing?
01 Silverado 4.8 155k - Mobil 1 HM 5w30 04 Cavalier (GF) 125k - Pennzoil Ultra 5w30 11 Civic LX Sedan 25K - Mobil 1 0w20
#2580420 - 03/26/12 04:04 PM
[Re: LckydevL]
Fluid exchange can't hurt anything. The use of the word "flush" has caused a lot of confusion, in my opinion. Unless you're pressurizing the transmissions, or using a solvent, a fluid exchange isn't a "flush," as Honda has so vehemently warned against.
I had this done (albeit by a shop with a professional fluid exchange machine) to switch my tranny over to the DW-1 last spring and experienced no problems. My first UOA on the ATF with 7800 miles should be in (and will be posted) any day now.
#2580426 - 03/26/12 04:08 PM
[Re: LckydevL]
I don't know enough to take a position either way. I do not have the design of hydraulic circuit so I don't know if the fresh fluid would neatly replace the old fluid in plug flow like my Toyota/Lexus cars do.
#2580525 - 03/26/12 05:20 PM
[Re: ltslimjim]
Loc: PL&F
Yes, this is an I4 Civic, with the A1 engine; non-flex fuel. I've seen different capacity transmissions listed connected to this Civic, not sure which A/T the LX/A1 comes paired together? Capacities vary, I could always pull out their manual. By the way, I'd also not consider the 'return line drain while adding new fluid until clean comes out' method as a flush job. It is a quicker method of new fluid entry is all, not a forcing of fluid in any direction other than normal A/T operation by using it's OWN fluid pump = not a flush. Good call on that. No harm in drains/re-fills. Just great to know it has a drain plug before I invest time/energy to coordinate only to find out it didn't have one and the job became more involved. Simple = better in this situation trying to help a friend that is harder to line up our schedules. So, switching to DW-1 right away is the recommended way? Has anyone used something like Lugegard red bottle ATF in a Honda transmission WITH bad symptoms already? (IF the fluid transition doesnt settle in well, just speaking hypothetical, not going to use additive right away or planning to at all right now, to be clear)
