Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
Difference between silicone caulking ?
by Merkava_4
05/29/16 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
05/29/16 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
05/29/16 05:13 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
56 registered (4WD, 2010Civic, 79Eldor, AirgunSavant, 3800Series, 6 invisible), 991 Guests and 321 Spiders online.
58013 Members
66 Forums
249581 Topics
Page 1 of 2 1 2 >
#2508134 - 01/28/12 06:05 AM Can I bleed all 4 brakes at once?
flyingtoaster Offline
Loc: Rancho Cucamonga, CA
I can't think of any logical reason why not, other than the reservoir draining 4x faster, and the fact that there is a bleed order for my car (which many people go by a different, unofficial order).
2006 Honda S2000
Rotella T6 5w40, OEM Filter
Amsoil MTF
Amsoil 75w140
ATE SL.6
#2508140 - 01/28/12 06:15 AM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
Smoky14 Offline
Loc: Nowhere NM
In a word, YES, but the flow is faster one at a time thus the chance of moving bubbles and dirt is more likely.
MHO
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
#2508141 - 01/28/12 06:26 AM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
Astro14 Offline
Loc: Virginia Beach
What do you mean by bleed?
If you're pressure bleeding - then I suppose you could, but how do you watch all 4 (in some cases more) points at once to know you're done?
If you're pumping the pedal, how do you close all 4 at once for the return stroke?
IF you're just opening all the bleeders and gravity draining, you're not going to get all the air out...
So, I am having trouble understanding what you're talking about...when I pressure bleed, if the car is already up...it takes 10 minutes, tops...and that's following the car's recommended order...
32 Packard 15W40
90 4Runner 10W40 Edge
92 300E 0W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#2508171 - 01/28/12 07:15 AM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
Bluestream Offline
Loc: Waterloo, ON
why on earth would you want to do this? YOu would have o go around and close each bleeder at the bottom of the pedal stoke to keep air from getting in. It would take forever to do.
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#2508191 - 01/28/12 07:52 AM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
berniedd Offline
Loc: A Warm place to live in
Normally, bleeding the brakes is a 2-man job. Now, if you want to do all 4 brake cylinders at the same time, you'd need 5 people. I don't see any advantage to that.
#2508210 - 01/28/12 08:16 AM Re: Can I bleed all 4 brakes at once? [Re: Astro14]
Vikas Offline
Loc: NorthEast
I have never done this myself but once (twenty years ago!) the mechanic did it for me. The car was in for some other job and he just hooked up the four bottles while he was working inside the engine compartment. I had phenomenal pedal after that.
#2508220 - 01/28/12 08:32 AM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
Tegger Offline
Loc: Canada
You sure can bleed all 4 at the same time. Just use the "gravity" method. That's where you simply open all the bleeders at once and allow the fluid to run through by itself, keeping a sharp eye on the reservoir so it doesn't run dry.
The problem I've found with the gravity method is that the calipers/cylinders don't always want to "start" unless you use a Mity-Vac, or mouth suction through a hose to get them going, and the dripping fluid can make a real mess on the brakes and floor. Putting hoses on caliper bleed nipples tends to prevent gravity from working, since caliper nipples tend to point upwards.
2013 Toyota RAV4 - 52,000 miles - Toyota 0W-20, Toyota filter
#2508237 - 01/28/12 08:47 AM Re: Can I bleed all 4 brakes at once? [Re: Vikas]
Artem Offline
Loc: Florida
I see no real benefit from doing all 4 at once vs 1 at a time and in the correct order.
If you get the 1 man bleeder kit x4 and hook up all 4 calipers at once, it could be done.
I usually like to take my time and have an assistant help with the brake pedal while i insure that ALL old fluid is removed and clean juice is coming out of each caliper.
Vikas, you had great pedal feel simply because the brake fluid was changed, not because of the method used duh
2015 Lexus ES300H with all the goodies - Factory Fill
2014 Mazda 3 Hatch i Touring 2.0L & 6spd - Mazda 0w20
#2508243 - 01/28/12 08:54 AM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
I forgot to mention that I am gravity bleeding with 4 silicone hoses and 4 bottles. Will it drip too slowly to move air? My lines usually bleed fast.
2006 Honda S2000
Amsoil MTF
Amsoil 75w140
ATE SL.6
#2508278 - 01/28/12 09:55 AM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
eljefino Offline
Loc: ME
Gravity bleed, yes. Otherwise I would worry that one corner has less restriction than the rest and would get most if not all of the new fluid.
How do they do it to new cars at the factory? I bet it's a gravity bleed, but would be very interested.
#2508441 - 01/28/12 12:46 PM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
Bluestream Offline
Loc: Waterloo, ON
So you have bleed these line before? What problems are you having that you need to do this again?
1991 BMW 735iL
#2508618 - 01/28/12 03:35 PM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
mechtech2 Offline
Loc: Chicago Area
For one man:
A 4 wheel bleed is viable for a gravity bleed and also if you have special bleed valve type bleeders and you pump the pedal [one way flow].
BTW, a gravity bleed IS a pressure bleed, just with lower pressure.
It works great, generally.
#2509574 - 01/29/12 05:15 PM Re: Can I bleed all 4 brakes at once? [Re: eljefino]
Tegger Offline
Loc: Canada
My understanding is that they use a pressure-bleed system at the factory. A device is clamped to the Master Cylinder reservoir and fluid is forced through until all bubbles are gone from the bleed nipples. I wonder how they deal with stubborn bubbles, such as those that can stick in rear calipers which incorporate a parking brake. Maybe the turbulence of the forced-fluid does that on its own?
#2509578 - 01/29/12 05:18 PM Re: Can I bleed all 4 brakes at once? [Re: mechtech2]
Tegger Offline
Loc: Canada
Originally Posted By: mechtech2
For one man:
These:
http://www.speedbleeder.com/
#2510014 - 01/30/12 01:32 AM Re: Can I bleed all 4 brakes at once? [Re: flyingtoaster]
mechtech2 Offline
Loc: Chicago Area
Yeah.... those.
Page 1 of 2 1 2 >
