Purolator L14476 with OPE
by SwampDweller
6 minutes 47 seconds ago
WRX or GTI?
by GumbyJarvis
Today at 02:50 AM
Single cylinder versus twin
by mjoekingz28
Today at 01:12 AM
Mobil Super Syn vs ...others
by Yup
Today at 12:45 AM
2016 WRX
by Silver02ex
Yesterday at 11:58 PM
Class Action Lawsuit Against Oil Filter Company?
by crazyoildude
Yesterday at 11:42 PM
PL10241 Cut Open
by Vegoose
Yesterday at 11:15 PM
Seems like common sense to me......
by Doog
Yesterday at 11:14 PM
Thinking of buying an old diesel Benz
by Diego3336
Yesterday at 10:46 PM
Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
Yesterday at 09:43 PM
2007 corolla oil pan steel or aluminum?
by Rolla07
Yesterday at 09:07 PM
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
Yesterday at 08:56 PM
engus, Rob_Pol, Nick24w, SkipKaye, MikeHancho
56899 Registered Users
50 registered (BillyTheKid, Al, 04SE, Astro_Guy, bullwinkle, bama7x57, 5 invisible), 664 Guests and 197 Spiders online.
56899 Members
66 Forums
244582 Topics
Page 1 of 2 1 2 >
#2440735 - 11/21/11 10:29 AM Can I use 10w40 in my vehicle?
zerosoma Offline
Loc: Omaha, NE
My vehicle calls for 5w30, and 10w30 in the right conditions (i.e. summer driving). I found some cheap 10w40 that I posted about from Valvoline and I'm wondering if it would be fine in my vehicle. It's the Hyundai in my sig.
Would I need to buy more oil to mix in with it so it takes down the viscosity more? If so I may return it because I won't have much use for it.
Can I use full 10w40 in my SUV?
Thanks!
Edited by zerosoma (11/21/11 10:29 AM)
2004 Hyundai Santa Fe LX 3.5L V6 (118k) [Mobil 1 0w40]
#2440747 - 11/21/11 10:47 AM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
carwreck Offline
Loc: CT
Of course you can use it.
But it may lower your gas mileage by 1-2%, will vary with car, and this loss may only be temporary.
My car also calls for 5W30 or 10W30. I had some 10W40 Valvoline that I used in an oil change.
Car takes 4.5 quarts; I mixed 1 qt 10W40 with 3.5 qts 5W30.
I did not measure mgp, but rpm dropped immediataly at idle by about 100 rpm. This was only temporary in my car. After about 2 weeks, the rpm's were back to normal.
________________________________________
1999 OLDS GLS 3.4L
#2440749 - 11/21/11 10:49 AM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
SuperDave456 Offline
Loc: Dallas, Texas
Being in South Dakota I would use it as top off oil in the Summers.
It is crazy cold there from what I understand. During colder months I would stick with your synthetic 5w30 and what not with the really low pour points.
I'm currently using a 40 weight in my 2002 Ford Taurus with its 3.0 SOHC V6 and 176,000 miles. However, It has a small leak that the 40 weight really slows down, and it only gets down to the 40's at night here, then back up into the 70's and 80's during the day.
Can you use it? Sure, but I'd be careful with your winters.
#2440758 - 11/21/11 10:54 AM Re: Can I use 10w40 in my vehicle? [Re: SuperDave456]
Brent_G Offline
Loc: Aberdeen SD
You could use it as a summer fill. But not in winter, run a 5w30 or 0w30. not sure what part of the state your in, but it gets cold pretty much everywhere lol
05 Grand Prix GTP
01 Ford F150
06 Yamaha R1
69 Roadrunner 528 Hemi
68 Dart GTS 512
71 Superbee's 440 and 383
87 Camaro 540 BBC
#2440786 - 11/21/11 11:21 AM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
chubbs1 Offline
Loc: Merritt Island FL, USA
As said above, just do not use it in the SD winter. Strictly a summer thing.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2440787 - 11/21/11 11:23 AM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
zerosoma Offline
Loc: Omaha, NE
Summers can get up to an average of 80-100 degrees, spring usually floats around 68-74. This would definitely be a summer oil.
I have to take it back anyway because I found out they charged me $3.99/qt when it was marked for $1.99/qt. So I either may return it or just have them give me my money back fully.
Thanks for the responses!
#2440817 - 11/21/11 11:38 AM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
yeti Offline
Loc: windsor, ontario, canada.
here's a thought -- your vehicle calls for 5w-30, so buy 5w-30 and use it. i don't understand why there are so many threads devoted to this topic -- can i use a (thicker/much thicker)oil in my car that calls for a 5w-30, or a 20w oil? 10w-40 won't hurt anything, but using that logic, go with a 20w-50, or mabye a 10w-60.not being sarcastic -- just go with the spec'd grade.
"there is no sense in having an argument with a man so stupid, he doesn't know you have the better of him." -- john raper
#2440826 - 11/21/11 11:43 AM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Running a grade heavier than spec' oil because it was cheap is usually false economy due to the reduced fuel mileage (whether you can measure it or not), unless the intent is to use it for blending purposes with a lighter than spec' oil.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#2440832 - 11/21/11 11:47 AM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
TFB1 Offline
Loc: VA
In ND I'd defiantly use it in the late spring, summer and early fall, then my right foot weighs about 40Lbs, gas mileage isn't a concern...
#2440861 - 11/21/11 12:14 PM Re: Can I use 10w40 in my vehicle? [Re: TFB1]
CATERHAM Offline
That's easy for you to say!
#2440876 - 11/21/11 12:27 PM Re: Can I use 10w40 in my vehicle? [Re: CATERHAM]
ammolab Offline
Loc: Ruidoso, NM USA
I have to wonder about the dangers of using a 10W30 or 10W40 oil in wintertime....
Back in the 'day' (1950s and 1960s) these 10W oils were the WINTER OILS!....and we worried about the "danger" of using these "W" (Water weight :)) oils in the SUMMERTIME!
2009 Honda CR-V
2002 BMW M Coupe
2011 BMW R1200R
1986 BMW K75C wrecked at 147,000 miles, RIP,
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
#2440980 - 11/21/11 02:28 PM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
old1 Offline
Loc: Nebraska USA rural
I swear that I have read on either this site or another that the multi weight oils 10/40 for example, are suppose to perform as a 10 wt. oil when cold, but retain the viscosity of a 40 wt. when hot. Is that right? so wouldn't warm weather use of a 10/40 be ok.
#2441066 - 11/21/11 04:35 PM Re: Can I use 10w40 in my vehicle? [Re: old1]
CATERHAM Offline
You don't have swear, I believe you.
Technology marches on and 10W-XX oils are no longer recommended for winter use. They are much heavier on start-up at all temp's than 5W-XX and 0W-XX oils.
A 40wt oil is simply heavier than necessary for your application.
#2441088 - 11/21/11 05:00 PM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
Cristobal Offline
Loc: Cal-Neva-Ari
I would only use it between April 1 and about the end of November in your area. Thet is a period of about 34 weeks.
Surrounded by ferocious, snarling, & spoiled Poodles!
#2441139 - 11/21/11 06:00 PM Re: Can I use 10w40 in my vehicle? [Re: zerosoma]
aquariuscsm Offline
Loc: South Texas,USA
Absolutely you can! Won`t hurt a thing. If you lived in Australia,here`s what Shell says:
Premium
HELIX ULTRA 5W-40
Standard
HELIX HX7 K 15W-50
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
Page 1 of 2 1 2 >
