Harbor Freight has the 900w generators on sale again so I picked one up. Pulled it out of the box and went to town on it.
Oiled the foam air filter with filter oil.
Added a fuel filter.
Replaced the troubleprone Chinese spark plug with an Autolite #64.
Put a few drops of oil down the spark plug hole. Sure did look dry down in there.
Mixed up some gas and oil. I used Stihl oil. I did add a little extra oil for break in. Prolly not needed but since I'm an oil nerd why not?
It started on the 2nd pull. I ran it an hr with a 200w load. Owners manual says it needs to run 25 hrs to fully break in.
This is my 2nd one of these. I noticed with my first one that after it breaks in it was running @ 140Volts.
This is adjustable but the owners manual doesn't tell you that.
I will check the output voltage after a few more hrs and adjust as needed.
