Anyone here gotten late life orthodontics?
by LoneRanger
08/29/16 12:30 PM
iPhone Touch Disease
by Pop_Rivit
08/29/16 11:22 AM
Windows RUN (tool) troubleshoot
by Triple_Se7en
08/29/16 10:58 AM
Spark plug gaps
by SpeedyG75VW
08/29/16 10:27 AM
Funny Craigslist ad
by Drew99GT
08/29/16 10:23 AM
Formula Shell dino
by Camprunner
08/29/16 10:05 AM
Linux Distro for laptop
by LeakySeals
08/29/16 09:24 AM
GM Pickup Trucks With G-80 Locker Read This
by Silverado12
08/29/16 09:12 AM
M1 EP 0w20, 12764 mi oci, 50302 mi 2013 RAV4
by SF0059
08/29/16 08:25 AM
AC blows dead animal smell with a huge vibration!
by puredata
08/29/16 08:04 AM
Oil consumption early vs. late in OCI
by skaughtz
08/29/16 08:03 AM
Kaepernick disses national anthem
by grampi
08/29/16 07:19 AM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
103 registered (1JZ_E46, 74Scout, 901Memphis, Al, 87sammy, AirgunSavant, 6 invisible), 1765 Guests and 9 Spiders online.
58952 Members
66 Forums
253721 Topics
Page 1 of 3 1 2 3 >
#2428622 - 11/08/11 09:00 AM 2012 Mazda5 Best Oil for Long Life?
caideN Offline
Loc: California
Hello. My father's 2012 Mazda 5 has hit 10,000 miles and is ready for it's 3rd oil change. I know the factory recommends 0w20 oil but I feel like its too thin. Would the engine last longer using 5w20 oil? Also, what oil and filter should I use? I've heard motorcraft or mobil 1 are good, but please share your knowledge.
Thanks!!!
#2428625 - 11/08/11 09:03 AM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
chevrofreak Offline
Loc: Billings, MT
You know that 0w-20 isn't really thinner than 5w-20, right? Right?!
I <3 Red Line oil
#2428636 - 11/08/11 09:11 AM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
caideN Offline
Loc: California
Really? I'm a newbie sorry...
Someone know the oil capacity with filter change for the 2012. My father misplaced his manual.
Edited by caideN (11/08/11 09:12 AM)
#2428639 - 11/08/11 09:14 AM Re: 2012 Mazda5 Best Oil for Long Life? [Re: chevrofreak]
Mark_Walk Offline
Loc: Danville, KY
Using Mobil 1 as an example...
0w20 viscosity at 100C is 8.7
5w20 viscosity at 100C is 8.9
...so the 0w20 is slightly thinner at operating temp than the 5w20.
2011 BMW328xi (M1 0w40) 105,000mi
2010 Mazda6iTP (MC 5w20) 136,000mi
2007 VolvoXC70 (M1 0w40) 139,000mi
2002 TrailBlazerEXT (PYB 5w30) 154,000mi
#2428641 - 11/08/11 09:16 AM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
Mark_Walk Offline
Loc: Danville, KY
Thanks!!!
As you can see from my signature, I'm in a similar situation with my two Mazdas. I'm running 20wt. in each (following manufacturer recomendations) but I'm going with 20wt. oils that are on the thick side of 20 weights.
#2428651 - 11/08/11 09:26 AM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
Quattro Pete Offline
Loc: Great Lakes
5.3 quarts, according to Amsoil's website.
http://www.amsoil.com/mygarage/ProductRecommendations.aspx?FromIndex=1&url2=2012+MAZDA+MAZDA5+D
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2428655 - 11/08/11 09:28 AM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
Mark_Walk Offline
Loc: Danville, KY
Both of my Mazdas with the 2.5 engine are 5.3qts with filter.
#2428668 - 11/08/11 09:48 AM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
caideN Offline
Loc: California
So what oil should I use to expect best engine life? That 1-2% FE I can careless.
#2428701 - 11/08/11 10:32 AM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
Artem Offline
Loc: Florida
It honestly depends on the driving style / conditions.
If you live in a really hot climate, a 5w30 could be beneficial, esp if the car is driven spiritedly and ran Hard on a daily basis.
If it's driven normally and doesn't see very high temps, the factory recommended 0w20 will have more then enough strength to protect the engine and help it outlast the rest of the car 2 or 3 times over. Trust me.
2015 Lexus ES300H with all the goodies - Factory Fill
2014 Mazda 3 Hatch i Touring 2.0L & 6spd - Mazda 0w20
#2428903 - 11/08/11 01:23 PM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
OceanDoctor Offline
Loc: Canada
Generally speaking, most 0w20s are formulated to a higher standard and built better than most 5w30s. I would go with the recomended viscosity, without a doubt. The oil systems (pump included) are designed to allow more oil flow which provides a better turnover rate at the point of friction than anything that may create a higher backpressure (that also uses mechanical energy to work against that backpressure).
Do not fall victim to SAE grade misrepresetation!
370K '97 Camry 2.2L - Winter Fill 50/50 PC 0w30 / Honda 0w20
150K '05 Pontiac G6 - 25% PYB 5w20 25% Honda 0w20 50% PC 0w30
#2428928 - 11/08/11 01:54 PM Re: 2012 Mazda5 Best Oil for Long Life? [Re: Mark_Walk]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
As it turns out you're correct that M1 0W-20 is lighter than M1 5W-20 but it's not because of the slight difference in the kinematic viscosity spec's. The 0W-20 has a lower HTHSV of 2.7cP and and a higher 173 VI vs 2.77cP and a 163 VI for the 5W-20.
It is these two viscosity spec's that determine how thick or thin an oil will be at any given operating temp' above freezing.
M1 0W-20 is actually thicker than most 20wt oils which tend to have HTHSV in the 2.6cP area which I'm sure is what it is for the Mazda Brand 0W-20.
BTW, the Mazda 0W-20 oil is one Japanese 0W-20 we know nothing about in the States. We know who makes the Toyota, Honda and Subaru 0W-20s but not Mazda. If someone could post a picture of the bottle that might help determine the source of their oil.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#2428988 - 11/08/11 03:11 PM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
tig1 Offline
Loc: Illinois
Thanks!!!
You used the word thin for 0-20. That is the wrong word for 0w oils. 0w oils are formulated to flow better in cold temps than 5-10w oils. 0w oils are not thinner but flow better. Here is a video from M1 describing how 0w oils work. Scroll down to the video on 0w oils.
http://www.mobiloil.com/USA-English/MotorOil/Videos/Videos.aspx
2007 Ford Fusion 187,000 miles
M1 0-20 AFE
2007 Ford Focus 158,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2429250 - 11/08/11 07:49 PM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
SXE10 Offline
Loc: New Zealand
We run JDM Mazda Golden SM 5w30 in that engine over here. They go to the trouble of importing 55 gallon drums of the stuff from Japan for our small market.
I'd stick to the 0w20 as listed by Mazda USA so you don't have any warranty issues if a problem occurs.
Once its out of warranty you might want to try a 0w30/5w30 as you'll have had the car for 60,000 miles/5 years.
'99 Altezza RS200-Z 3SGE 6MT - Motul 300V 5W-30 I Gear300 75W-90 I Gear Competition 75W-140
'06 Toyota Wish X 1ZZFE - Motul H-Tech 100+ 5W-30 I ATF-1A
#2429270 - 11/08/11 08:04 PM Re: 2012 Mazda5 Best Oil for Long Life? [Re: caideN]
Merkava_4 Offline
Loc: Clovis, CA
No, but it would probably last longer using 10W-30.
#2429280 - 11/08/11 08:11 PM Re: 2012 Mazda5 Best Oil for Long Life? [Re: Merkava_4]
Patman Offline
Loc: Oakville, Ontario
I highly doubt that. The engine was designed to run on 20 weight oils, so running a thicker oil is really not doing it any favors, especially on cold starts.
2005 Corvette (M1 5w30 & Fram Ultra)
2006 Civic EX Coupe (M1 0w20 & M1 filter)
2010 BMW 328i X-Drive (M1 0w40 & Mann filter)
Page 1 of 3 1 2 3 >
