To change or not?
by ram_man
07/29/16 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
07/29/16 11:20 PM
Camaro "How its Made" TV show Observations
by SumpChump
07/29/16 11:08 PM
Wondering if sitting with few quick starts degrad
by corndogzombie
07/29/16 10:51 PM
whole hog cook w/ pics
by 04SE
07/29/16 10:12 PM
redo a/c in 1994 dakota 2wd
by bmwjohn
07/29/16 09:37 PM
How to post UOA's on here?
by motor_oil_madman
07/29/16 09:34 PM
Remanns Brand Remanufactured engines
by TiredTrucker
07/29/16 09:11 PM
Best long lasting door hinges lurbicate ?
by MetalSlug
07/29/16 08:59 PM
How do you clean trunk area (not inside the trunk)
by MetalSlug
07/29/16 08:57 PM
Gas prices do the ol' switcheroo
by grampi
07/29/16 08:44 PM
Possible Valve adjustment needed?
by andrewp1998
07/29/16 08:16 PM
jractk, LatitudeDancer, AKN, NickGB, Marcusd1979
58645 Registered Users
47 registered (95wagon, 2015_PSD, Anthony, bmod305, 901Memphis, cjcride, 5 invisible), 1161 Guests and 7 Spiders online.
58645 Members
66 Forums
252427 Topics
Page 1 of 3 1 2 3 >
#2422832 - 11/01/11 10:30 PM Cold piston slap, thicker oil?
CBR.worm Offline
Loc: Jupiter, Fl
My FX has always had cold piston slap, not bad. it goes away as it warms up, but sounds like a diesel when ambient temps drop below 60ish. I typically run M1 0w40. Should I go to something thicker when cold? Living in Florida I don't exactly need cold weather protection.
'06 Infiniti G35 Sedan 6MT - 160k
#2422837 - 11/01/11 10:38 PM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
It probably won't make a big difference but is try it. Try 10w30 or 10w40
2004 Honda civic vp -m1 5w30
1998 Saturn sl2 -mobil super 5000 5w30
#2422849 - 11/01/11 10:48 PM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
ammolab Offline
Loc: Ruidoso, NM USA
Your oil is THICKEST when cold... It the slap goes away when things warm up(oil now thinner)...how would a thicker oil help that piston slap?
Or is it the temp of the piston/parts that matters?
Edited by ammolab (11/01/11 10:49 PM)
2009 Honda CR-V
2002 BMW M Coupe
2011 BMW R1200R
1986 BMW K75C wrecked at 147,000 miles, RIP,
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
#2422859 - 11/01/11 11:00 PM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
MrRPM Offline
Loc: Michigan
its probably the temp of the pistons that cause that. as they get hot they expand to the proper size/shape, as they are desighned to do.
so i could maybe see how using a thicker oil at start up could help cushion the piston slap, but who knows if it actually would work.
try it!
2001 Jeep Wrangler 4.0L, 5qts Quaker State DEFY 10w-30/1qt kendall GT-1 20w-50, FRAM XG8A (ultra)
#2422905 - 11/02/11 01:39 AM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
chubbs1 Offline
Loc: Merritt Island FL, USA
Can you use a 0w30? M1? That is what I would try, I am another who doesn't understand how a thicker oil would stop COLD piston slap. If you decide to go thicker and it helps please let me know, I would be surprised. M1 0w30 or the thicker Syntec 0w30 should do the trick. The Former being my choice, especially since we are getting towards our cold months. I had a neighbor with cold slap and I told him to go thinner and it was gone that day. Never had that issue again.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2422912 - 11/02/11 02:15 AM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
aquariuscsm Offline
Loc: South Texas,USA
Try either a 10W40 dino or if you want synth,M1 10W40HM. I bet either of these will do the trick. I`d try the dino first. Let us know how it turns out.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#2422919 - 11/02/11 02:35 AM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
Merkava_4 Offline
Loc: Clovis, CA
Try some MaxLife 10W-40.
#2422951 - 11/02/11 06:18 AM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
SteveSRT8 Offline
Loc: Sunny Florida
As the owner of many 'slappers' I can tell you this. Get used to it. No oil is likely to help, as it's not clearances where oil is pressurized.
If it is real piston slap it will disappear very quickly, unlike a valve gear noise which can hang around a bit. On our engines it has absolutely no effect at all on the life or performance of the engine.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2422963 - 11/02/11 06:50 AM Re: Cold piston slap, thicker oil? [Re: SteveSRT8]
TFB1 Offline
Loc: VA
There you go, in a nutshell...
I could maybe see thicker oil helping if the slap was slight but usually the only thing that stops it is piston expansion as it heats up... Piston slap is basically the piston rocking slightly in the cylinder and while it likely won't cause a issue, I'd give the engine a minute or so to get heat into the pistons before I'd drive it...
#2423033 - 11/02/11 08:51 AM Re: Cold piston slap, thicker oil? [Re: SteveSRT8]
Boss302fan Offline
Loc: Oconomowoc Wi
Ditto.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#2423116 - 11/02/11 11:08 AM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
KCJeep Offline
Loc: Mahzurrah!
We have two "slappers", a 2000 Chevy 3.1 and a 2004 Chevy 3.4, both slap loudly when cold, both quite down quickly, and fooling with different oils has never made a bit of difference that I can detect.
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 62k, Ford Focus 116k, Chrysler Sebring 186k, Chrysler Concorde 120k
#2423151 - 11/02/11 12:02 PM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
Bambam Offline
Loc: CT
How about using a block heater all the time, warmer engine less slap?
07 DMAX CC 4x4
265 Cooper AT3's
Bilstein 5100's
T-C pump rub fix
EGR Blocked
PCV rerouted
efi live tuned
#2423159 - 11/02/11 12:10 PM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
aquariuscsm Offline
My 2nd 3000GT I owned "slapped" with thinner synths. Dino made it go away completely. Some engines just seem finicky for some reason.
Amsoil MTG(tranny)
Mobil 1 ATF
#2423187 - 11/02/11 12:39 PM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
SteveSRT8 Offline
Loc: Sunny Florida
You very likely proved it was not piston slap at all.
#2423207 - 11/02/11 01:11 PM Re: Cold piston slap, thicker oil? [Re: CBR.worm]
Ken2 Offline
Loc: Washington St.
My Tundra has had a cold piston tick for the last 115,000 miles with no changes, and I'm not worried about it. Some oils damp sound better than others, but there is really no reason to be concerned about the noise that goes away when warm. The aluminum pistons expand and contract more with heat changes than the cast iron block, so they're made to be loose when cold. No problem.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
Page 1 of 3 1 2 3 >
