20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
05/26/16 03:48 AM
new castrol edge high mileage synthetic
by hiflo
05/26/16 03:32 AM
Just an interesting question
by southernjeeper
05/26/16 01:52 AM
Value power Walmart battery acid flying out
by bbhero
05/26/16 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
05/25/16 10:35 PM
Steak-House Burgers
by sleddriver
05/25/16 09:53 PM
Got into an accident.
by bdcardinal
05/25/16 09:42 PM
Its coming here more and more
by CourierDriver
05/25/16 08:40 PM
Interpreting oil pressure vs engine RPM
by Emperors6
05/25/16 08:39 PM
$4 Fram Ultra - Blain's F&F
by Poohbah
05/25/16 08:21 PM
Toolbox - Pliers
by greasegunn
05/25/16 08:09 PM
ProSelect Oil Filter????
by qwerty1234
05/25/16 08:05 PM
jerryg, 1971tr350, Mak712, Lex4TDI4Life, cdub76
57988 Registered Users
32 registered (chriscpmtmp, Boomer, alcyon, BigD1, bourne, 4 invisible), 655 Guests and 333 Spiders online.
57988 Members
66 Forums
249414 Topics
#2360105 - 08/28/11 12:55 PM Accidentally overextended
thesheik Offline
Loc: Tampa Bay
I've been using Maxlife Semi 5/30 in my '02 ES300 for a few years. The car has 170K miles on it and runs like new. I normally change my oil between 5 and 6K like clockwork and use a Pure One filter.
You couldn't believe the horror when I discovered this last change that I had gone 10K. I didn't realize it was that long as I'm usually on top of these things.
So just to make sure if this happens again, I bought Mobil One HM 5/30. And of course the Pure One filter. As a matter of fact, this is the way I might go from now on and extend my changes to 10K as the $7 price difference between ML and M1 isn't all that significant.
#2360115 - 08/28/11 01:03 PM Re: Accidentally overextended [Re: thesheik]
sciphi Offline
Loc: Upstate NY
Don't worry about it. I'm sure the Maxlife and P1 didn't notice the difference.
Just watch out for burning on the M1, especially since it hasn't seen full synthetic oils in a few years. M1 burned off in an older car I tried it in. Our Honda doesn't burn a drop of M1 0w-20, and it's run a full synthetic since 11k miles.
2009 Honda Fit Sport
2012 Chevrolet Cruze Eco
#2360120 - 08/28/11 01:09 PM Re: Accidentally overextended [Re: sciphi]
thesheik Offline
Loc: Tampa Bay
Thanks. I'll keep a close eye on it.
#2360124 - 08/28/11 01:16 PM Re: Accidentally overextended [Re: thesheik]
tinmanSC Offline
Loc: Oswego, IL
The 2002 ES300 uses the 1MZ-FE engine doesn't it? That engine is widely known as a sludge monster. It's what started Toyota's engine sludge issues. Keep your oil change interval low and change your PCV valve often!
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
#2360131 - 08/28/11 01:23 PM Re: Accidentally overextended [Re: thesheik]
Sayjac Offline
Loc: The Old North State
tinman beat me to it, this vehicle is a known sludger. That said, one time with a good oil and filter combo following regular maintenance, going to 10k once isn't going to spell the end of the engine.
Because it's a sludger, think I'd stick to no more than 5-6k OCI's with this vehicle in the future, even with M1 or other syn.
Curious how long(time) it took to reach the 10k?
#2360136 - 08/28/11 01:35 PM Re: Accidentally overextended [Re: tinmanSC]
thesheik Offline
Loc: Tampa Bay
I think the sludge issue depended on when the car was manufactured.
Mine was manufactured after that date.
#2360145 - 08/28/11 01:48 PM Re: Accidentally overextended [Re: thesheik]
HTSS_TR Offline
Loc: Lake Forest, CA
I would do 6-7k/8-10 months OCI for the first use of M1, then extend to 10k/12 months after that.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2360149 - 08/28/11 01:50 PM Re: Accidentally overextended [Re: HTSS_TR]
thesheik Offline
Loc: Tampa Bay
That was my thought exactly.
#2360168 - 08/28/11 02:14 PM Re: Accidentally overextended [Re: thesheik]
Sayjac Offline
Just know the 02 ES300 is on the sludger list.
Before I'd start running 10 k OCI I'd verify that your vehicle is definitely NOT included in 02 listing. If I couldn't, I'd stick with no more than 5-6k OCI's even with M1/syn, cheap insurance. But, your call.
welcome
#2360206 - 08/28/11 03:18 PM Re: Accidentally overextended [Re: thesheik]
LeakySeals Offline
Loc: MA
Any chance of cutting that filter open?
02 Camry XLE 2AZ-FE 348k M1 HM 5w30
06 Escalade 135k. M1 5w30
#2360246 - 08/28/11 04:18 PM Re: Accidentally overextended [Re: Sayjac]
thesheik Offline
Loc: Tampa Bay
The sludger list pertains to Lexus manufactured up to 7/01.
Mine was manufactured in 10/01 so I should be alright.
#2360376 - 08/28/11 07:33 PM Re: Accidentally overextended [Re: thesheik]
wiswind Offline
Loc: Wisconsin
The newer version of the 1MZFE motor had a improved PCV valve and valve cover.
The old style PCV valve was a plastic unit that pressed into a grommet in the rear valve cover.
The new style PCV valve is a metal unit that screws into the rear valve cover (same location).
I have a 2003 Toyota Sienna, which is outside the "gelling" issue years with the same engine as your ES300
Personaly, I like to stick to the shorter Oil Change Interval.
One reason, as you experienced.....If I don't get to it right when it was due, I have a safety buffer built into my program.
How long it takes one to put the miles on is a factor.
If you are doing a lot of highway miles, not much short trip driving and you put a lot of miles on.....then you are less likely to develop sludge as long as you use a quality oil and filter....check the PCV valve to make sure that it does not become clogged, and othewise keep up on your routine maintenance.
I went with a longer oil filter.....exact same dimensions otherwise, same threads, same pressure bypass.
PLENTY of room for the longer filter.
The numbers are......
Pure One
PL20195 4.74" long in place of PL10241 3.36" long
More recently, I have been using
Bosch Distance Plus D3422 in place of D3330
It is also made by Purolator but has a heavier can and more dirt holding capacity.
I like both filters.
The first oil changes, I used the WIX filter.
Here is a picture of the filter that was on the vehicle when I got it, vs the longer filter.
#2361904 - 08/30/11 12:27 PM Re: Accidentally overextended [Re: thesheik]
weebl Offline
Loc: Canada
I am doing factory spec'd OCIs (5k miles), even with a synthetic, and the engine I have is the 3MZ-FE, a decendant of the 1MZ-FE that should have this issue long cleared. But because of its lineage, I feel better not going crazy with my OCIs, and using syn since they tend to be more sludge resistant than dino.
Even though your 1MZ-FE is supposed to be outside the window of issues, remember it traces back to a fundamental design flaw, and Toyota only did a band-aid fix on one of the contributing factors.
2006 Toyota Sienna - 3.3L 3MZ-FE
2014 Volkswagen Passat TDI MT - 2.0L CKRA
#2362354 - 08/30/11 08:11 PM Re: Accidentally overextended [Re: weebl]
wiswind Offline
Loc: Wisconsin
Exactly why a 5K mile OCI with a quality synthetic and a bigger capacity oil filter is my approach.
I also pulled the valve covers and had a look around, installed new valve cover gaskets, PCV valve and spark plugs.
The timing belt was changed at 89K miles as well as the water pump at a TOYOTA dealership (was cheaper than a quality independant shop).
I am VERY confident that these are good motors, when properly maintained, which is sounds like you are doing.
